Is there a way to make my own Datalogging cable for the serial port? So I don't have to buy anythin
Old Jun 16, 2005 | 04:19 PM
CivicDXRaceCar's Avatar
Default Is there a way to make my own Datalogging cable for the serial port? So I don't have to buy anythin
I want to datalog using uberdata, do I have to buy the Max232 adapter or can i make my own for the serial port? Are there other ways to get this thing to work other than buying **** off line? What cables are you guys using? Do you use the techedge wideband? How do you hook it up to datalong in uberdata?
Old Jun 21, 2005 | 08:12 AM
civic-4-ges's Avatar
Default Re: Is there a way to make my own Datalogging cable for the serial port? So I don't have to buy any
Max232 or some kind of RTP board required for serial use, USB cable with some kind of convertor for USB use
I was using the Max232 with a simple serial cable, worked great
Wideband datalogging requires you to disable the o2 sensor within Uberdata. The wideband will privde different voltage readings than a stock o2, and the ecu will ignore it, however still allow it to pass through-to the datalogging port you install
psv4878
Engine Management and Tuning
Aug 19, 2010 09:48 PM
LoseRPunKx182
Jun 9, 2008 11:38 AM
LoseRPunKx182
Mid-Atlantic (Sales)
Jun 5, 2008 05:33 PM
LoseRPunKx182
Jun 5, 2008 05:31 PM
LoseRPunKx182
Northeast (Sales)
