question about relocating the battery -- distribution block
Old Jun 16, 2005 | 03:43 PM
crdcz03's Avatar
Fortune Cookie Member
Default question about relocating the battery -- distribution block
im installing one right now and theres this thing called a "distribution block." the one i have is like a lil cylinder with four bolts sticking out of it. 2 bigger and thicker ones (which i assume one goes to the fuse box and one goes to the starter), but then there are two little ones... one has an I next to it and the other one has an S next to it.
so im wondering what do i screw onto there? (and if my assumptions for the two bigger ones is correct?)
Old Jun 16, 2005 | 04:01 PM
crdcz03's Avatar
Default Re: question about relocating the battery -- distribution block (crdcz03)
ok after searching (and finding people arguing about wiring it inside or outside, a bunch of broken links, and people asking what battery they should use) i came across hawkze saying something about using a distribution block and "connect the ignition and stereo to that if you have it"
could ignition and stereo be the I and S!?!?
Old Jun 16, 2005 | 05:22 PM
Hawkze_2.3's Avatar
Honestly, all you have to do is connect all the things that need a positive connection to the + battery terminal. A distribution block makes it easier, but it's not necessary. You could probably get by with a nut and bolt holding the wires tightly together. I wasted $50 on a dist. block
For example: hook the dist. block to the + batt. cable and then connect the fuse box + wire, the starter + wire, your amp + wire, etc....
Old Jun 16, 2005 | 05:40 PM
crdcz03's Avatar
Default Re: question about relocating the battery -- distribution block (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, all you have to do is connect all the things that need a positive connection to the + battery terminal. A distribution block makes it easier, but it's not necessary. You could probably get by with a nut and bolt holding the wires tightly together. I wasted $50 on a dist. block
For example: hook the dist. block to the + batt. cable and then connect the fuse box + wire, the starter + wire, your amp + wire, etc....</TD></TR></TABLE>
well i already have the distribution block... so ill prolly use it lol.
and i dont have a system so im assuming i dont need to hook up an amp wire (or is that an abbreviation for something not related to a sound system? lol)
heres a very rough sketch of what it looks like (my parents took teh camera to Jamaica )
so... lets say i hook it up like so:
top: power wire from battery (i believe i have a 4ga wire)
bottom: starter (what gauge should i use?)
right: fuse box (what gauge should i use?)
or could i hook the starter and the fuse box wires onto the bottom one. i ask b/cc those little ones are freakin tiny and dont look like i should use them
Old Jun 16, 2005 | 06:11 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, that should work.
Old Jun 16, 2005 | 06:48 PM
crdcz03's Avatar
Yeah, that should work. </TD></TR></TABLE>
ok im prolly gonna do that then.
now all i need is teh connectors.
thanks dood
Old Jun 16, 2005 | 07:22 PM
shdriver99's Avatar
Hey I had all the wires on that distribution going to one of the big ones. It's quite simple!
LKSi
Jun 11, 2007 09:30 PM
B18EG6
Audio / Security / Video
Aug 31, 2006 04:22 PM
GoFastTshirts.com
Jul 25, 2006 01:24 PM
smash fascism
Apr 6, 2005 03:03 PM
jbiggsSE
Aug 4, 2004 10:14 AM
