NEED TO RE-WIRE MY H22.....
Old Jun 16, 2005 | 03:39 PM
xd69's Avatar
Default NEED TO RE-WIRE MY H22.....
Here's the deal....
i have a jdm h22a(looks to be a 94 block) and my head is stamped 97. the place where i got my swap done said that my swap would be an obd1 jdm h22. im now thinking that my head is usdm obd2(my intake mani. looks way too different from the jdm h22). im running an obd1 p28. my car has been running like **** so i took it to "ACCUHOND". this guy is supposed to be the ****, if he cant do it, then it'll be hard to find someone that can. he couldnt fix my car. he said that my wiring was all fucked up and that he didnt want to **** with it. so basically i have to re-wire my ****. can you guys direct me to someone that will be willing to take on this problem??........
Old Jun 16, 2005 | 07:13 PM
Lord_attilas's Avatar
Default Re: NEED TO RE-WIRE MY H22..... (xd69)
WEll... if you wiring is all mixed up.... that will cost you a lot of money to get it right, because wiring problem can be a real mess sometime... and good technician will take some time to figure out how they did your car's swap...... I would suggest you take the time to look under your hood and start getting things done by yourself... Especialy when you get a swaped motor, it would be a really nice things for you to understand what is going on under your car hood !!!
Just try to find out your car SERVICE BOOK or SERVICE MANUEL ( On Ebay or on PTP sharing in PDF format ).... there is all necessary wiring diagram in there. Also try to get wiring from your JDM motor.... from there... take the time or just ask a friend (which is good in electronic) to help you out !!!! It will be a little more time consuming... but you will end up with a lot more money, and way better comprehention of your swapped motor !!!
May be my reply will not help you out... but at least it can give you some motivation to get it work properly !!!! )
Good luck !!!!!
Joe Donohue
Feb 5, 2017 03:21 PM
97ludedude
Sep 19, 2008 03:38 AM
pkolaboy
May 24, 2008 08:43 AM
xd69
Jun 16, 2005 07:20 PM
