Does it worth to port & polish an ITR Manifold??
Old Jun 16, 2005 | 02:28 PM
chechin's Avatar
Default Does it worth to port & polish an ITR Manifold??
Hi I recently got an ITR Manifold, my setup is on my sign the only difference is that now I'm going w/Skunk2 Pro Cams and 2.5" collector, I use my car for drag racing/daily drive, what do you guys think about porting & polish this manifold would this help me to get more high end power or it just could make lose some mid range torque?
Old Jun 16, 2005 | 03:18 PM
Rocket's Avatar
Default Re: Does it worth to port & polish an ITR Manifold?? (chechin)
It will help.
Old Jun 16, 2005 | 05:44 PM
chechin's Avatar
Default Re: Does it worth to port & polish an ITR Manifold?? (Rocket)
thanks
Old Jun 16, 2005 | 05:47 PM
chechin's Avatar
Rocket, by the way do you know where can I buy Online some gen2 RM valve springs?
Old Jun 16, 2005 | 05:54 PM
HBK GABE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chechin &raquo;</TD></TR><TR><TD CLASS="quote">Rocket, by the way do you know where can I buy Online some gen2 RM valve springs?</TD></TR></TABLE>
w0w r u just trying to play dumb? lol
look at his sig
Old Jun 16, 2005 | 06:00 PM
chechin's Avatar
Default Re: Does it worth to port & polish an ITR Manifold?? (626CivicSi)
nope I'm serious I got in his website m24x.com but there doesn't appear how to buy online. It may sound dumb but it's true.
Old Jun 16, 2005 | 06:02 PM
337 GTI 1.8t's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chechin &raquo;</TD></TR><TR><TD CLASS="quote">Hi I recently got an ITR Manifold, my setup is on my sign the only difference is that now I'm going w/Skunk2 Pro Cams and 2.5" collector, I use my car for drag racing/daily drive, what do you guys think about porting & polish this manifold would this help me to get more high end power or it just could make lose some mid range torque?
polish?...hmm, i would not polish. port, if done within reason, sure...but don't polish, keep it relatively textured, like stock runner-interior texture.
Old Jun 16, 2005 | 06:18 PM
PyroProblem's Avatar
Default Re: Does it worth to port & polish an ITR Manifold?? (337 GTI 1.8t)
I would think the smoother the better since you want as little friction as possible.
You dont really need turbulence until you try to mix fuel with it.(I believe)
I would say yes it will help also. Probably help your powerband in the upper regions.
Old Jun 16, 2005 | 06:23 PM
Rocket's Avatar
Default Re: Does it worth to port & polish an ITR Manifold?? (PyroProblem)
Contact me via e-mail is best or a dealer.
Old Jun 16, 2005 | 06:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">I would think the smoother the better since you want as little friction as possible.
I would say yes it will help also. Probably help your powerband in the upper regions.</TD></TR></TABLE>
It is difficult to port much more than middle to end of the runners of the intake manifold, unless you cut it like Endyn does to get into the plenum & runner entryways, then weld back together. I am assuming the thread starter is not intending on cutting and welding, so he is probably inquiring about treatment to the middle/end of the runners, since these areas are the easiest to reach for a DIY guy. It is the middle to end of the runner area that you want to start promoting fuel atomization and also, this area is one that i would not polish.
Old Jun 16, 2005 | 06:53 PM
chechin's Avatar
email sent
Old Jun 16, 2005 | 06:59 PM
chechin's Avatar
that is correct I'm not intended to cutting the IM, only porting & polishing (maybe) from the middle to the end my idea was in order to make the runners exactly match the same size and polish work as the intakes of the head (which is already p&p).
Old Jun 16, 2005 | 09:02 PM
HBK GABE's Avatar
gl hope it comes out good
Old Jun 16, 2005 | 09:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chechin &raquo;</TD></TR><TR><TD CLASS="quote">my idea was in order to make the runners exactly match the polish work as the intakes of the head (which is already p&p).</TD></TR></TABLE>
matching the runners to the port/gasket is a great idea, however...the ported head should not have the intake port polished as you mention. If it does, rough it up with some 500 grit and do not polish the runners from the middle on out....
raverx3m
Mar 8, 2013 09:39 PM
SpeedingHatch
Dec 22, 2005 10:09 PM
Adam West
Dec 11, 2005 09:05 AM
Maxboost00
11
Feb 7, 2005 11:57 AM
Bulldogg83
Oct 8, 2003 07:56 PM
