b16 problem
Old Jun 16, 2005 | 01:07 PM
starbury's Avatar
Default b16 problem
ever since i took my AC out my b16a2 is idling really low at stop lights, almost to turning off. i have a skunk 2 manifold, and stage 1 clutch and 9lb flywheel but everything else is stock. is it cause of the stock header? throttle body? or maybe even spark plugs? if anyone has any ideas let me know
Old Jun 16, 2005 | 01:10 PM
spectacle's Avatar
Default Re: b16 problem (starbury)
bump cuz my car is idling low as **** as well. but never cuts off or stutters...
Old Jun 16, 2005 | 02:29 PM
808_si's Avatar
not sure about the ac, but having a skunk2 IM hurts power, on a bone stock motor...something you may want to look into, bigger cams and better flowing exhaust...
what does it idle at? mine stock si idles at like 400rpms...
Old Jun 16, 2005 | 02:32 PM
Punker1234's Avatar
Default Re: (808_si)
is 400 rpm really low still? isn't it suppose ot be 750?
Old Jun 16, 2005 | 02:35 PM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si &raquo;</TD></TR><TR><TD CLASS="quote">not sure about the ac, but having a skunk2 IM hurts power, on a bone stock motor...something you may want to look into, bigger cams and better flowing exhaust...
what does it idle at? mine stock si idles at like 400rpms...</TD></TR></TABLE>
Since when does it hurt power on a stock motor? Dyno results I've seen show 5-8 hp over stock and mine definitely doesn't feel any slower after the im swap.
To the original poster, I have the same motor, same im, and no ac, and the only time I had that problem was after the im swap. Try adjusting the throttle screw.
-Shane
Old Jun 16, 2005 | 02:36 PM
P.S.
Never do an open poll like that unless absolutely necessary.
That's the kind of answer you will get almost every time.
-Shane
Old Jun 16, 2005 | 04:23 PM
neutron91's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">Try adjusting the throttle screw.</TD></TR></TABLE>
Old Jun 16, 2005 | 04:26 PM
The_Todd's Avatar
Farts in the shower
Adjust your idle...I believe stock idle is around 700-800 rpms. I believe there is a throttle/idle adjustment screw at the top of the throttle body.
Old Jun 16, 2005 | 05:11 PM
808_si's Avatar
-Shane</TD></TR></TABLE>
dyno results i've seen shown to hurt power until upgraded cams and exhaust are added. but if you experienced gains, more power to you!
Old Jun 16, 2005 | 06:04 PM
spectacle's Avatar
the hotter it is outside the lower my idle is....
Old Jun 16, 2005 | 07:00 PM
Bond's Avatar
Default Re: (spectacle)
Just adjust your idle higher. The idle is suppost to be 750rpm when at normal operating temp. After I swaped my stock flywheel (16.5lbs.) with my chromoly one (8.36lbs.) I never had to adjust my idle. I don't think the flywheel made the idle go down. Since idle is getting worse when the engine is hot I would say to check and clean your <U>IACV</U>, check your timing, check your PCV and then adjust your idle.
db_de_luxe
Dec 9, 2010 05:23 PM
b16a4
10
Jan 16, 2007 02:16 PM
b16a4
Jan 16, 2007 11:23 AM
Used2beAb16
Feb 9, 2006 09:20 AM
riceball777
Aug 18, 2003 10:11 AM
