dyno results
sorry couldnt put the picture coz my scanner is broken. neway kinda dissapointed i was aiming for 200+hp but 1st run was 187.3hp and 168.7tt/lb. final run was 196.7hp and 175.3ft/lb. i have jrsc 6psi, aem short ram, greddy sp, and apexi vafc 2. its street tuned and vtec is set to 4500. the tuner said that u would have reached 200+ if i upgrade my header. im running on stock header for now.
Yeh, the stock header with a 2" collector does plug stuff up a bit. Not sure if Kamikaze makes a 4-1 for your car but they work well on GSR SC'd engines. If they make one make sure it has a 2-1/2" collector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">Yeh, the stock header with a 2" collector does plug stuff up a bit. Not sure if Kamikaze makes a 4-1 for your car but they work well on GSR SC'd engines. If they make one make sure it has a 2-1/2" collector.</TD></TR></TABLE>
Yes they do, and if you look hard enough you can find one for cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chanluder »</TD></TR><TR><TD CLASS="quote">the result is so dissapointing. its manual. im buying a dc stainless header. im gonna dyno tune it again.</TD></TR></TABLE>
Nah dont go that route, DC sports headers are made to work with stock cat thus 2.0inch collector which sucks for a setup like yours, or any other setup at that. Look for a kamikazi header
Here http://www.importparts.com/sho...=1799
What's up with max power coming in at only 6200 rpm?
My max power with the JRSC was 249hp @ 7400 rpm. (Stock header by the way.) Have you done a compression check? You do have an H22 A4 in there right?
louie3252
Mar 24, 2006 10:51 PM
STN_Pat
Dec 19, 2003 03:37 PM
red civic standard
24
Dec 10, 2003 05:43 PM
