ASR subrame brace+EG+ ASR 32mm hollow swaybar.....doable?Done?
Any EGs with this bar? Just wondering if the EG ASR brace will work with the ASR 32mm bar. I am awaiting a response from ASR, but thought I would see if anyone has done it.
Are there any other companies that make the hollow bar sway bars that might work with the ASR brace?
Thanks.
Thanks.
hello im installing a H22 in my 92 hatch, and i was wondering what kind of sway bar i should get for my car. I was goiing to do with the ASR subframe/bar combo since i know they will work... does the diameter of the bar have to do with how stiff it iwll make the car?
yes the diameter has alot to do with the stiffness. also hollow bar takes away it.s torsional "stiffness". the leverage arm length also changes "stiffness".
oh ok, well since i know nothing and will resarch a bit... in your opinion or anyone who looks at this and wants to comment, what kind of bar would you go for to correct understeer and anything really associated with the H22 transplant? *don't say.. dont put it in* lol....
speaking antiroll bar wise. a bigger diameter rear bar vs front bar will reduce the presence of "understeer".
VTECIntegra9
Jan 20, 2011 06:00 AM
