will a 97 itr dizzy work in my 99-00 si engine?
Old Jun 16, 2005 | 06:53 AM
97civic123's Avatar
Default will a 97 itr dizzy work in my 99-00 si engine?
did a search but came up short. will the legs match up. will it work?
Old Jun 16, 2005 | 06:55 AM
b204dr's Avatar
legs will line up - but the question is what obd will you be running? and the wiring !
Old Jun 16, 2005 | 06:59 AM
97civic123's Avatar
Default Re: will a 97 itr dizzy work in my 99-00 si engine? (97civic123)
it's a 99 usdm si engine.
Old Jun 16, 2005 | 07:02 AM
b204dr's Avatar
The engine can be any thing you want b seires vtec- b16 or b18 but what chassis ! what obd!
If its all 99-00 si car & engine - the dizzy wont work right because plugs wont line up and would need to be wired - if chassis is obd2a like 96-98 civic or 96-99 i think it is teg- then you are fine slap the dizzy in and if it is using the obd2a wiring harness all should line up! I hope this explains enough
Old Jun 16, 2005 | 07:29 AM
97civic123's Avatar
Default Re: (b204dr)
thanks. it's a 96 ek, but i ran an si engine with si engine, and dash harness.
blaze the chemi's Avatar
It should line up. There are a few numbers and letter on the metal of the dizzy to tell you the model it came out of. I have an ITR on my B16A and it was converted to OBD2. Not sure how it was wired, but it does work.
JDM_CRX_PLEASE
Jan 9, 2008 03:37 PM
jdmed8
Dec 17, 2003 07:17 PM
