!!Need Help!! *Clutch Problem*
Old Feb 11, 2002 | 12:43 PM
REDBARON's Avatar
Default !!Need Help!! *Clutch Problem*
Ok guys here's my problem. I installed the motor mount bracket on top of the trans because the bolt that holds the motor mount to the bracket fell off. So needless to say my engine was hanging low without that mount. Well I installed a new bracket and got everything back up. Now after the install I went for a test drive and the clutch was kind of hard, then I reach a stop sign and it won't release in the gear. I can put the car in gear, but after I let go of the pedal it won't go anywhere. I can also put it in gear without stepping on the clutch. WTF!!! I need help guys. Any suggestions would be really helpfull. Also this is an ACT clutch if that helps any.
Thanks.
Racso_626
Sep 12, 2015 08:58 PM
redflaredcrx90
Apr 18, 2009 03:38 PM
sivik_outkast
13
Jul 14, 2006 04:43 AM
