tools for the ecu?
I need to add the knock sensor form the engine harness connector to the ecu connector. Porblem is I dont have a clue what tool should be used for conectors that plug into the ECU. Any information provided will be much obliged.
What obd? Take out a pin that you dont need and use that wire to connect the KS and repin it. Look here to know how:
https://honda-tech.com/zerothread?id=1171263
