****LOTS OF STUFF FOR SALE - B-series, cars, etc. *** updated daily
last updated 8/07/2006
- 94 and up Acura Integra Steering wheel & Air bag - black
-OBD1 P75 ECU, Acura Integra LS,$100
-91-93 Acura integra Springs - Ground Controls, green, $60
-88 to 93 Acura Integra tokico blue shocks. In great condition, $100 for all four.
-88 to 93 Acura Integra LS cable tranny, slightly grinds into 1st, $200
-Acura Integra LS OBD1 engine harness
-99 GSR swirlies, 2 only, scratched up. – great for track.
<U>SWAPS & Motors</U>
- B18B1 head, nothing wrong with it.
- B18a1, LS complete head
- B16a1 JDM 1st gen, complete bottom end, no knock sensor, unassembled, bare.
<U>AFTERMARKET</U>
- P2P OBD2a 1996 and up Honda Civic EX ecu
- P2P Automatic ECU Honda Civic EX OBD2 2000
- RAZO - RED, Carbon fiber shift ****. $10
- Autometer Phantom Air fuel ratio gauge, white face, black ring, $40
- Autometer Phantom Fuel pressure gauge, white face, black ring - no sending unit,$20
- Autometer dual gauge pod black for 92-95 Honda Civic
- STR yellow/goldish dipstick
- Hood pins, silver polish new.
- Blue Oil Cap aftermarket
- RAZO shift ****, carbon fiber x 2, ONE THREADED, ONE NOT
- LS shift ****, - really dirty
- 16" Rota GT3 center caps, polished.
- Rear tokico Shocks, less than 5K, EG or DC, $60
- 92 and up Honda Civic hatchback, HONDA Floor mats, don't know if it's the same with coupes, $40
<U> ACURA INTEGRA, B-series parts</U>
- 94 and up GSR, P72 power steering pump. x 4
- 94 Integra LS power steering rack, lines, pump,line coolers, bottle, needs one tie rod
- 94 Integra, cruise control modules, computer, lines, cables, even button
- 1994 and up Integra Hood latch & lines
- 1994 and up Integra Steering wheel & airbag 150
- 2001 Acura Used alarm w/ harness, easy plug and play -(keyless entry)
99 Integra stock CD head unit, doesn't play CD's - good for radio have the code
94 and up, Integra stock springs
94 and up, Integra AC condenser, compressor
94 and up, Integra stock side skirts – stock red
94 and up, GSR intake ARM w/ filter
94 and up, LS crank Pulley, non-obd & obd1
94 and up, Integra Cruise control module & pedal cable & module.
- B-series Top tranny mount $20
- B-series Driver side post mount & bracket
PR3 intake manifold w/ fuel rail
PR3 crank pulley, w/ V-belt ring
B-series OBD1 alternator, $50
B16a stock cams w/ cam gears, $40
B16a2 2000 USDM Crank, less than 8K miles.
B16a2 rear coolant water pipe
B18A/B, Acura Integra LS cam caps
B18a1, post mount & bracket
B-series Cranks angle sensor w/ sprocket
B-series oil pan, LS & B16a
B-series VTEC valve cover $40 - condition 7/10 needs repaint
B-series plug wire cover - spray painted black,$10
B-series injectors, NON-OBD, OBD2
B-series flywheel stock x 4, $30
B-series alternator mount x 3 $20
B-series crankshaft pulley, LS
B-series tensioner, x 4
B-series plug wires, lots of used sets,
B-series power steering mounts. P72 & P54
B-series AC compressor
B-series stock exhaust manifold top half only
B-series pilot bearing, Cable, new in box
B-series Oil sump
<U> HONDA CIVIC, D- series parts</U>
2001 Honda Civic Stock CD player, with code
96 CX VTEC head
2000 Honda Civic EX coupe, stock piping, $50
96 & up Civic Aluminum Oil pan, black & silver x 2
92-95 Honda Civic Cruise control module - with cables x 3
92-95 Honda Civic stock springs
92-95 Honda Civic mud flaps, give me an offer! don't know if it's for coupe or HB
94-95 Honda Civic - Condensor
D-series 92-95 driver side mount
D-series 92-95 top tranny mount
D-series 92-95 front tranny mount
D-series 92-95 rear tranny mount
D-series Alternator OBD1 & OBD2 x 8
D-series Crank pully & pin
D-series alternator mounts
D-series Fuel rail
D-series throttle bodies, all missing TPS's
D-series Injectors, obd 1 & 2's
D-series shift linkages for 88-91 & 94 and up.
D-series starters, Si, DX, etc
D-series Intake manifolds, Si & DX x 6
D-series flywheel x 5
D-series valve cover, NON-VTEC
D-series thermostat housing
D-series plug wires
D-series head studs
<U>MISC – bolts and etc.</U>
Any bolt on a Honda or Acura, tranny bolts, mounts, 10mm,12, 14, 17, 19
Plugs for every part of the car, except ECU & distributor & lights
IAT sensor x 4
IAC valves x 3 only the wide bolt pattern
Fuel Pressure Regulator x 10, B,D, all kinds
Stock plug wires x 8 B-series D-series
OBD1 injector clips (plugs) and partial harness
OBD2 injector clips (plugs) and partial harness
B20 engine harness, OBD2, LS should be the same?
Seats belts, front, back, everything, for Integra & Civic's
Some Stock Prelude/Accord mounts
Lots of AC lines for 92 and up civic
Upper A-arms, Civic & Integra
Front shock forks
T3 turbo exhaust housing – 5 bolt flange - NO 4 bolt
T4 turbo polish housing x 2, don't know the sizes.
2000 Honda Accord V6 Starter, brand new in box!
H22 VTEC cams w/ cam stock cam gears x 2
H22 VTEC starter, $40
60" piping for header back for an integra or civic
Nissan 240 hood S13, $20
Nissan 240 driverside and passenger side windows, $10 each
S13 Nissan ECU, KA20DE motor, $20
"Y" manual switch exhaust pipe, cast iron, & lever
Motorized scooter, suspension
2001 - 2005 BMW M3 passenger side fog light
2001 - 2005 BMW M3 front bumper, needs repair
2001 - 2005 BMW M3 passenger side headlight, HID, broken tabs good for DIY HID
2001 – 2005 BMW M3 – Eibach springs, only rear, lowers .9”
2001 – 2005 BMW M3 – Vogtland Springs, front lower 1.2” and rear .8”
2001 - 2005 BMW M3 – Tein S Springs, Front lower 1.5” and rear 1.3”
<U>WTT: I want or trade for</U>
2001 and up E46 BMW one Headlight – need one more for HID Conversion
I have lots of pictures; you can email me Mugen21@socal.rr.com. Please be specific, year/model/make/engine/and your offer of how much.
IF YOU TOOK THE TIME TO READ THIS ENTIRE POST, PLEASE BUMP!!! I’d be surprise if you did go down this far! If you did, low ballers are welcome but may not be acknowledged! NO FLAMING please. GO Flame somewhere else.
Modified by Tuan at 1:47 PM 8/7/2006
<U>AFTERMARKET</U>
B-series Oil sump
96 CX VTEC head
D-series Fuel rail
D-series plug wires
D-series head studs
IAT sensor x 4
Front shock forks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 »</TD></TR><TR><TD CLASS="quote">Hey whats up? I pmed you and told you I wanted the dip sticks and you told me to e-mail you so I did and I have never heard any reply again??</TD></TR></TABLE>
I've been real busy. I think i sold it awhile back, but i have to double check .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecPower323 »</TD></TR><TR><TD CLASS="quote">BUMP
thank you!
thank you!
