clutch question...
Old Jun 15, 2005 | 06:55 PM
ludermark's Avatar
Default clutch question...
ok, so now sometimes when I push in my clutch I can hear a squeek coming from inside the engine bay. The squeek is not always apparent but it happens once and a while. Also sometimes when I am getting on it high in the rpm's in 2nd gear I can hear a loud squeek that goes on for about a solid second...
I have no idea what is going on hear but Im hoping it is just in need of lubrication. Clutch functions normally and feels perfectly fine.
Old Jun 15, 2005 | 08:15 PM
luderacer_92's Avatar
Default Re: clutch question... (ludermark)
a quick check that you can do is see if the fork is making noise on you slave cylinder, i had a squeaking problem and that is what i found it to be...
Old Jun 16, 2005 | 05:19 AM
Sephro's Avatar
Default Re: clutch question... (luderacer_92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luderacer_92 &raquo;</TD></TR><TR><TD CLASS="quote">a quick check that you can do is see if the fork is making noise on you slave cylinder, i had a squeaking problem and that is what i found it to be...</TD></TR></TABLE>
That is a very very common place to get a squeak from..
But you say it lasts for a few seconds? I was thinking at first TOB but you said it's when you get on it... Are you sure that's not a belt slipping???
gianlumase
Honda Civic (2001 - 2005)
May 18, 2013 12:39 PM
JdMhEaD
Oct 24, 2006 11:22 AM
JDM B16A
Mar 23, 2006 02:08 PM
initialpatch
Feb 17, 2006 02:02 AM
E Swift
Dec 1, 2004 02:57 PM
