d15b7/d16z6 head swap
Old Jun 15, 2005 | 03:42 PM
delsoltnr's Avatar
Default d15b7/d16z6 head swap
im putting and d16z6 head on a d15b7 block... i need to know if the distributor is interchangable w the d16z6 head and what timing belt to use....i was told to use the belt from a honda civic "vx" w/103 teeth instead of using the d16z6 timing belt...and this is all going on a 93 honda del sol s if that makes a difference...
Old Jun 17, 2005 | 12:58 PM
delsoltnr's Avatar
Default Re: d15b7/d16z6 head swap (delsoltnr)
Old Jun 17, 2005 | 01:01 PM
d16singlecammer's Avatar
https://honda-tech.com/zerothread?id=554053
Its been covered a billion times before, please use the search button.
Thanks
Old Jun 17, 2005 | 01:07 PM
USDMGD3!'s Avatar
u use the Z6 timing belt and the dizzy arent interchangeable... u can fabricate it to work by notching the legs on the dizzy but its up to u... when i lined up my B7 dizzy to the Z6 head it fit but the legs were way off...
pinoy369
Apr 24, 2007 06:00 AM
EF9ZC
Mar 4, 2006 10:40 AM
crohnman6
Jan 3, 2006 03:28 PM
ssl2k
Jun 9, 2005 12:02 PM
ssl2k
Feb 24, 2005 11:16 AM
