Emanage on H23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon »</TD></TR><TR><TD CLASS="quote">Stock engine/bolt ons. very little gains if at all. Comparable to VAFC.</TD></TR></TABLE>
You can pick up a little more power if you go with the add-on that allows you to alter ignition timing. E-manage is better than the afc in my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">
You can pick up a little more power if you go with the add-on that allows you to alter ignition timing. E-manage is better than the afc in my opinion.</TD></TR></TABLE>
I dont even think you will pick-up 2 digit numbers with tuning alone.
I dont even think you will pick-up 2 digit numbers with tuning alone.</TD></TR></TABLE>
tahts is really up to waht mods you have done, and how far you are from stock.
on an h22 i tuned, we picked up 12whp, from dialing in the fuel and igintion on the emanage vs. stock ecu. that was on a cammed h22.
well here is what I have so far.
H23
ported and polished head and port matched intake mani
Dual valve springs
Aluminum retainers
Megan racing headers
5zigen catback
Jun lightweight flywheel
testpipe(insted of a catalytic converter)
a cold air intake
17 lbs 5zigen rims
I plan on getting the harness for the ignition and injectors...does anyone know what type of numbers I will be looking at? I plan on dyno it in a month or so (spent to much money on the head work.
H23
Dual valve springs
Aluminum retainers
5zigen catback
a cold air intake
17 lbs 5zigen rims
Spunkster
Dec 11, 2004 07:57 AM
