suspension for a 4dr 92 integra LS?
Yes, the 2 door suspension from 90-93 Integras would fit, as would the suspension from an 88-91 Civic/CRX (except for the rear shocks from a 88 CRX). Also, if you swap out the front drop forks and pick up some from a 94-01 Integra or 92-00 Civic, you could use 94-01 Integra (except ITR rears) or 92-95 Civic shocks as well.
No problem, for tips on the G2 Integra, you should also check out http://www.g2ic.com. All of the info you asked about is in their 'Hybrid Suspension Article'
eREXion91
Suspension & Brakes
Mar 8, 2005 09:56 AM
