Map sensor picture
Old Jun 15, 2005 | 01:19 PM
Ronin150's Avatar
Default Map sensor picture
I'm doing a ls swap and I needed a picture of an ls swapped crx dx (don't know if the map sensors are all the same) map sensor. If the hf and si map sensors are the same then post those up also.
Also another question is what would I use to plug up the holes in the firewall for the charcoal cannister and also on the motor?
TIA
Old Jun 15, 2005 | 01:49 PM
aeonsi's Avatar
Default Re: Map sensor picture (Ronin150)
map sensors are different between the tegs and civics. I had posted a similar question about this for my b16 EF9. use it its works way better for correct air/fuel ratio. plus make sure you use the pressure cut-off solenoid valve. its cylender in shape and has two-lead plug. theres two of these things the other is called the purge cut-off solenoid valve. but this is the same on the civics. heres a vacuum diagram though its fro an SiR the map/cut-off assemply is routed the same. hope this helps.
Old Jun 15, 2005 | 02:05 PM
Ronin150's Avatar
Default Re: Map sensor picture (aeonsi)
Thanks much. Are you saying to use the teggy map or just use the same one I have in there?
Old Jun 15, 2005 | 03:41 PM
rioninja's Avatar
The map sensors are not functionally different. Use the one you already have.
boostedcivicsir
Oct 26, 2008 02:14 PM
zman
Jun 15, 2006 07:40 PM
SOHC_DK.
May 6, 2004 07:43 AM
DC 2
Mar 9, 2004 07:00 AM
Yellow Dragon
Jul 23, 2003 02:01 PM
