Symptoms of Low tranmission fluid..
what are the symptoms of low tranmission fluid??
I'm just trying to figure out what is wrong with my car now that my setup is working right.. It could very well be the cluthc..
I had an incident where when boosting my speedo went crazy.. but i can hear like a loud WAAAAAA sound but it's not pulling..
well, the vss could be going wrong.
if you press on the gas and the engine revs but not accelerates, then its your clutch.
what symptoms are you getting?
nope didn't buy the car with the turbo..
VSS?? well the car drives normal.. it seems to pull hard as hell in 2nd gear.. spins tires even.. but i guess it's heating up or something and then it doesn't grab.. cuz it seems to pull hard a few times then decides it's not going to do it anymore..
made use of the search function.. I tried before but I tried again and found my answer.. thanks for the repliesmmuller and red91sit
Laceyfer
Transmission & Drivetrain
Jun 28, 2011 02:19 PM
jdmsleeper12
May 18, 2010 11:50 AM
