turbo dx, swapped motor, w/out mpfi conversion
I have a crx dx and had to swap my motor. I bought a non vtec sohc zc (basicly a d16a6) the motor is in and works fine, but i didnt convert to mpfi from dpfi...
Could I do this :
http://www.homemadeturbo.com/turbo_projects/d15b2/
and be fine???
The guy installed larger injectors into the dpfi system and claims to have good results. This would seem easier.... Would the stock ecu respond well to bigger injectors and add the correct timing and a/f ration. I'm also interested in adding water injection and how the stock ecu will respond to it.
the mpfi conversion seems to be too much work.
Could I do this :
and be fine???
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
convert it, everything else you had planned is a lot more work than converting th multipoint.
stan
stan
only reason I see to keep DPI would be you dont are so scared of being trendy you rather run that beat *** old system
beatthisspeed69
Apr 24, 2007 05:36 PM
