b16 header fit b18 (ls)?
Old Jun 15, 2005 | 09:47 AM
SiR Inspired ED7's Avatar
Default b16 header fit b18 (ls)?
i was wondering if the b16 header fits the b18. anyone? thanks
Old Jun 15, 2005 | 10:28 AM
Default Re: b16 header fit b18 (ls)? (88 Crx Si)
Old Jun 15, 2005 | 11:04 AM
HONDA_TYPE_R's Avatar
Yes it will. I bolted my B16A in and it had a Chikarust already on it. It mated up to the cat with just a little stretch and extra tightening of the bolts on the flange.
Old Jun 15, 2005 | 02:32 PM
purplegsr's Avatar
Default Re: b16 header fit b18 (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will. I bolted my B16A in and it had a Chikarust already on it. It mated up to the cat with just a little stretch and extra tightening of the bolts on the flange.</TD></TR></TABLE>
I am not sure that it works the other way around though, yes, a b18 header would fit on a b16 head because the bolt pattern, etc is the same. However, b16s are shorter than b18s when measured from header bolts down to the bottom of the oil pan. So, a b18 header works fine on a b16 (leaves a little bit of room under the oil pan), but a b16 header will often hit the oil pan on a b18 because the bend in the header occurs too early.
Old Jun 15, 2005 | 02:38 PM
G-bonic's Avatar
Hijacked
Default Re: b16 header fit b18 (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">
I am not sure that it works the other way around though, yes, a b18 header would fit on a b16 head because the bolt pattern, etc is the same. However, b16s are shorter than b18s when measured from header bolts down to the bottom of the oil pan. So, a b18 header works fine on a b16 (leaves a little bit of room under the oil pan), but a b16 header will often hit the oil pan on a b18 because the bend in the header occurs too early.</TD></TR></TABLE>
Well said..
Old Jun 15, 2005 | 08:23 PM
Nice point...didn't think of that.
Old Jun 15, 2005 | 10:34 PM
al3e's Avatar
i was thinking about that. the 1.6 and the 1.8 difference had to come in somewhere... good ****.
ChiLS
Sep 15, 2008 06:45 PM
WhiteVX
Jun 15, 2006 06:43 AM
T3k C
Mar 30, 2006 01:17 PM
AllMotorRP
Dec 6, 2004 01:01 PM
X2BOARD
Oct 15, 2004 06:18 PM
