battery draining, please help
Well I've had this problem for some time now. luckily this isn't my dd but I still need to fix it as soon as possible. It seems like the battery drains in no time if the car isn't running. I'll have it running at night, leave it and by the next morning it won't have any charge. Not enough to turn over half a turn or even click.
I've tried the multimeter between battery post and terminal measuring amperage while removing fuses one by one looking for a drop in current draw method, but draw remained the same. It was cosistant from fuse to fuse, but over the time decreased from 1.35 amps when I started to 1.28 by the time I was done. Is 1.35 amps normal current draw with the engine off?
a couple of days ago I noticed that the door open switches/actuators were there (bought it as a shell). I though maybe that was the reason since I know some relays pull power when the switches are open. well, I replacend them yesterday and tried to start it again this morning...nothing.
BTW, battery is less than 2 months old. hold 12v just fine (car will start the next morning or next week as long as I leave the neg terminal off) and alternator was replaced a couple of months before that (~14v with motor running).
Are there any unfused circuits that I could check? Any other ideas
Cliffnotes:
Battery drains overnight.
checked everything I could think of
need ideas to fix
TIA
Cliffnotes:
need ideas to fix
TIA
no radio at all
the light isn't hooked either. I was just thinking, I didnt check for a open hatch switch. is there even one there? if there is chances are it's missing that too
braypunt
22
Sep 11, 2005 09:10 AM
barefootbilly
14
May 25, 2004 06:32 AM
