Do I need to grease new lower ball joint?
Old Jun 15, 2005 | 07:34 AM
copperfox's Avatar
Default Ball joint removal
95 Civic Si hatch. Search is down.
I found the answer to my first question: The answer is yes. Take off the boot on the new ball joint, fill with grease and then put the boot back on.
HERE IS MY NEW QUESTION
Noob --> Does the ball joint come out the bottom or top of the spindle?
Modified by copperfox at 10:30 AM 6/15/2005
Old Jun 15, 2005 | 09:27 AM
copperfox's Avatar
Default Re: Edit: Ball joint removal (copperfox)
bump, need to know for tonight
Old Jun 15, 2005 | 09:31 AM
snatch's Avatar
You should not have to grease the new balljoint.
When you remove the knuckle, spindle, whatever, it will come out from the top. You will hammer/push it out from the bottom, or the side where the threaded portion extends.
Is this for the lower balljoints?
Old Jun 15, 2005 | 09:42 AM
copperfox's Avatar
Default Re: Ball joint removal (copperfox)
Sorry, yes it is for the lower ball joint.
I realize that the upper ball joint is attached to the A arm and is not replacable by itself.
Thanks, that answered my question. But on Honda-acura.net they say you do need to grease the ball joint. Now I am confused.
Old Jun 15, 2005 | 10:02 AM
snatch's Avatar
When I bought my lower balljoints, they were pre-packed with grease, all I had to do was pop them in.
Good luck with the c-clamp for that goes around the body of the joint. That was a bitch to get on. I ended up removing the boot so that I wouldn't tear it trying to get the clamp on. In a roundabout way, this is how I found out they were packed with grease.
edit: Where are you buying them from?
Old Jun 15, 2005 | 02:29 PM
copperfox's Avatar
Autozone, $25 each. They come with the castle nut, cotter pin and snap ring.
EDIT: They ARE filled with grease!! I took the boot off and there it was. The grease in the new boot is white, and the grease in the old boot is dark brown, so I assumed since it didn't squirt out that there was none.
Old Jun 16, 2005 | 04:41 AM
snatch's Avatar
Sounds about right, I got mine from Napa. They came with all the same things too. The grease in mine was white as well. Any luck getting them put on yet?
Old Jun 16, 2005 | 08:12 AM
CardDealer's Avatar
Banned
Default Re: Ball joint removal (******)
Modified by CardDealer at 4:52 PM 11/16/2006
themtn
Honda Civic (2001 - 2005)
Mar 26, 2010 03:01 PM
halocore
Mar 7, 2009 04:34 PM
redDAinteg
Feb 22, 2009 09:00 AM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
DEL HATCH
Dec 16, 2006 01:57 PM
