itr rear sway bar
If I have itr lower control arms on my gsr, do i still need a BSQ kit or Beaks kit to prevent tare out of my itr sway bar?
I'm almost postive i should, but ive had mixed reviews on the subject.
thanks
thanks
EDIT: Beat me to it.
Yes sir, you still need the BSQ or Beaks kit. The ITR lower control arms actually don't add anything you need for the ITR sway bar system. The endlinks are the same on the ITR and the GSR/LS/etc.
The BSQ/Beaks kit takes away the chance that the rear subframe will tear. It's a totally separate piece from the control arms. Get it...it's only $20
A suggestion: If you don't already have the parts (sway bar, bushings, etc). Go to http://www.ahmotor.com and give their 1800 number a call. Ask for the Type R sway bar kit and they'll send you everything you need for about $104. This includes everything except the BSQ/Beaks kit.
