ALL MOTOR PARTS, ENGINE/TRANNY/MISC PARTS
i might part out to go a different route...
its time for bigger and better things...
ONLY if i know for a fact that these parts can sell
no flakers, dreamers, then im willing to part out
WILL NOT PART OUT OF THE SET
PACKAGE 1-
B18 A/B B20 B/Z
*COMPLETE HEAD PORTED POLISHED BY JG
*MILLED .030
*CROWER DUAL VALVE SPRING
*CROWER RETAINERS
*RED STR CAM SEAL
$400
PACKAGE 2-
*RED AEM CAMGEARS
*B18 a/b B20 CROWER 404 STAGE 3 CAMS
$440
PACKAGE 3-
*B18 A/B B20 B/Z JG MANIFOLD PORTED TO FIT 70MM TB (W/IAT/IACV/VACBOX/TROTTLE BRACKET)
*HONDATA MANIFOLD GASKET
*70MM BBK TB (W/TPS/MAP SENSOR/GASKET)
$400
PACKEGE 4-
*STR FUEL RAIL (W/ALL FITMENTS)
*B&M FP GUAGE
*AEM FPR
$200
PACKAGE 5-
*STOCK HEAD W/IM/RAIL/REG/INJECTORS/WITH ALL SENSORS
*95 B18B COMPLETE BOTTOM BLOCK
W/ 6k's miles ACT STREET DISC/OEM FLYWHEEL/ACT PRESSURE/
NEW 4k's miles WATERPUMP/TENSIONER/BELT/
80k's miles, 185 compression across the board
$550
PACKAGE 6-
*96-00 JDM **** DRIVER'S SIDE MOUNT
*99-00 SI DRIVERS SIDE ENGINE MOUNT
*99-00 SI REAR TRANNY BRACKET
*99-00 SI TRANNY MOUNT
*99-00 TRANNY SUPPORT MOUNT
$150 (EVERY MOUNT YOU NEED FOR A B-SERIES IN 96-00 CIVIC CHASSI)
PACKAGE 7-
*DC SHORT SHIFTER
*DC SHIFT ****
*B-SERIES HASPORT SHIFT LINKAGE
$120
*JDM B16 TRANSMISSION
$500
*B-SERIES HASPORT STAGE2 AXLES
$250
IF I HAVE ENOUGH PEOPLE INTERESTED IN IT
THEN I WILL START TO PART OUT
EVERYTHING IS STILL IN MY CAR/DAILY DRIVEN
PAKAGE DEALS ARE ALL INTACKED WHEN PRESENTED IN THE SALE/TRANSACTION
I TOOK SEVERAL YEARS PIECING UP MY MOTOR UP TO BUILT A 210WHP ALL MOTOR B18B ON STOCK BORE -WITH PACKAGE 1/2/3/4 WITH HIGHER COMP PISTONS, ARP BOLTS/RACE HEADERS (SMSP/DTE/ANR/ETC), GIRDLES, EASY 210WHP REVING TO 8000 RPM'S SAFELY ALL DAY WITHOUT THE VTEC
I WILL HAVE PICTURES UP SHORTLEY
EMAIL ME AT vani11aic3@sbcglobal.net
PACKAGE 1-
B18 A/B B20 B/Z
*MILLED .030
*CROWER RETAINERS
*RED STR CAM SEAL
$400
PACKAGE 2-
*RED AEM CAMGEARS
$440
PACKAGE 3-
$400
PACKEGE 4-
*B&M FP GUAGE
*AEM FPR
$200
PACKAGE 5-
$550
PACKAGE 6-
PACKAGE 7-
*DC SHORT SHIFTER
*DC SHIFT ****
$120
$500
$250
BUMP
BTW- I ALSO HAVE CROWER 402-T CAMS $320
404 CROWER CAMS ACTUALLY ARE NOT BAD AT ALL, IDLES LIKE STOCK JUST A BIT LOOPEY.. ALMOST HAVE THE SAME SPECS AS THE GSR CAMS..
I am interested in this:
PACKAGE 3-
$400
So you are saying that this will bolt right up to my B18A correct? I am converting my B18A to OBD-1, there would not be any problems right? Dumb question but I can't be TOO sure about stuff.
PACKAGE 3-
$400
package 1/2
dyno proven 154whp 124wtq!!! have dyno's sheets
on stock airbox/headers!! on a completely stock ls motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aLLmTreK »</TD></TR><TR><TD CLASS="quote">
lmk if more interested!!
When did you want me to come and pick up #3? I wanted to do it today but couldn't get ahold of you.
</TD></TR></TABLE>When did you want me to come and pick up #3? I wanted to do it today but couldn't get ahold of you.
