ITR steering rack on EG6/9!!!
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnhuZ »</TD></TR><TR><TD CLASS="quote">Hi ppl,
Does anyone know if it is a bolton???</TD></TR></TABLE>
the itr/dc2 rack (all of them are the same, 16:1, 2.98 turns ltl) is a bolt in to the ego chassis. if you have power steering, you will need to eliminate the one small line on the stock civic rack (this is the small line that goes to the small nipple on the p/s fluid resevoir)
a few years ago i did this on my 94 civic si. currently i am looking into elec power steering and a s2k rack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">
if you have power steering, you will need to eliminate the one small line on the stock civic rack (this is the small line that goes to the small nipple on the p/s fluid resevoir)</TD></TR></TABLE>
My EG9 have power steering... that is a complete removal, right?? the DC2 power steering circuit does not have that line, right??
I will install only the steering rack for now, but later i will install the complete circuit (pump, pipes, reservoir)...
humm.... no bolton, i assume. how will you adapt this???
Thanks very much Rodney,
</TD></TR></TABLE>humm.... no bolton, i assume. how will you adapt this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnhuZ »</TD></TR><TR><TD CLASS="quote">My EG9 have power steering... that is a complete removal, right?? </TD></TR></TABLE>
as far as swapping the integra rack, it is a complete unbolt the old one, bolt in the new one affair. the civic rack has 3 p/s line, the integra one has 2. so, you need to plug on on your cars system. the integra rack is also 5 lbs lighter....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnhuZ »</TD></TR><TR><TD CLASS="quote">humm.... no bolton, i assume. how will you adapt this???</TD></TR></TABLE>
dunno yet, as i have only been looking at them in the cars complete. i will most likely have to fab up some brackets, but i'll figure it out.
And that's all we want.....lightness
I want to go along with this project of yours... keep that posted here
</TD></TR></TABLE>I want to go along with this project of yours... keep that posted here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">You n00bs.
I'm collecting parts for my rack swap.
same here..
</TD></TR></TABLE>same here..
</TD></TR></TABLE>Ya I know right...Rodney's the biggest n00b ever!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Ya I know right...Rodney's the biggest n00b ever!
you are just jealous of my Jasma Vtech....
</TD></TR></TABLE>you are just jealous of my Jasma Vtech....
I just ordered the P/S rack, rear crossmember, LCA's, and shock forks so that I can do this swap in my EK...
any advice anyone can thorw my way. I have been told with the rear crossmember it is a bolt on affair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">I just ordered the P/S rack, rear crossmember, LCA's, and shock forks so that I can do this swap in my EK...
</TD></TR></TABLE>Crossmember = suframe?
Because I know that the teg/ek subframes are bolt up affairs but you can't bolt up a teg rack to an ek subframe. I'm sure you're well aware already.
</TD></TR></TABLE>Crossmember = suframe?Because I know that the teg/ek subframes are bolt up affairs but you can't bolt up a teg rack to an ek subframe. I'm sure you're well aware already.
it is my understanding that you cannot use (bolt in anyway) a eg/dc2 rack in an ek. if you have access to a welder, anything is possible.... in that case, just get a 00-03 s2k rack. it is the shortest honda rack ever made.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">it is my understanding that you cannot use (bolt in anyway) a eg/dc2 rack in an ek. if you have access to a welder, anything is possible.... in that case, just get a 00-03 s2k rack. it is the shortest honda rack ever made.
</TD></TR></TABLE>ltl? ratio?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">.... in that case, just get a 00-03 s2k rack. it is the shortest honda rack ever made.
</TD></TR></TABLE> you are make me want to do the same....
once the s2k rack in place (welded or bolted, whatever), what to do with the rest of the circuit ?? ...
i heard a lot about the "funny" feeling (like indirect, delayed, dont know how to explain) of the s2k steering, for it to be electrical...what do you guys think of it??
Modified by UnhuZ at 10:57 AM 6/15/2005
Modified by UnhuZ at 11:39 AM 6/15/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">ltl? ratio?</TD></TR></TABLE>
shooting off the top of my head (specs are on my home computer) the 00-03 st00k is 2.4 ltl, 13.8:1. they changed it in 04+ to 14.5:1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Crossmember = suframe?
Because I know that the teg/ek subframes are bolt up affairs but you can't bolt up a teg rack to an ek subframe. I'm sure you're well aware already.</TD></TR></TABLE>
Yah, I got the steering rack and the rear crossmember (sub-frame). You can't bolt the EG/DC rack to an EK rear crossmember, but you can bolt an EG/DC rear crossmember to an EK chassis. At least this is what I have been told by Hasport, then you can bolt the EG/DC steering rack on to my EG/DC sub-framed EK chassis. I just also have to switch out the LCA's and the strut forks.
Right?
P.S. what is teh going rate for the ITR rack? I picked up all of this stuff for $300 shipped...
Right?
Right?
</TD></TR></TABLE>Right.
So you picked up everything you need for the PS conversion for $300? I'd say that's not bad.
Right?
</TD></TR></TABLE>Right. So you picked up everything you need for the PS conversion for $300? I'd say that's not bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Right.
So you picked up everything you need for the PS conversion for $300? I'd say that's not bad.</TD></TR></TABLE>
Yup, thank you Import Auto Salvage, that price was including shipping to CA I think he said it was $240 befor shipping.
And I already have P/S just wanted the ITR rack and the rear crossmember so I can get a little better clearance with my K swap.
anyone know if the P/S will be plug and play? I was just reading what Rodney said about the P/S line on the EG's. I am not to sure how many lines are on my OEM rack in my 99 DX hatch? Hopefully there is just 2 one to the pump and one to the resiviour?
silentdaredevil2
Dec 4, 2005 05:42 PM
BoostedSixthGen
Aug 12, 2003 03:33 AM
