question about crx suspension
i have a 88 crx hf i took off my suspension off my 00 si and i want to put it on my crx off this website http://www.kteller.com/store/i...3_203
what LCA'S do i order??
Thanks for any help
Thanks for any help
itr rear lca = crx rear lca, eye mount though... if you want the ek fork mount... uhmmm eg i guess? as eg = dc right?
anyways, for the front there's no real other possibility than oem jdm siR ones, or DA integ I guess... the 92+ civic front lca is completely different...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverstone00Si »</TD></TR><TR><TD CLASS="quote">i have a 88 crx hf i took off my suspension off my 00 si and i want to put it on my crx off this website http://www.kteller.com/store/i...3_203
Thanks for any help
I assume "suspension" means coilover assemblies.
The EK LCAs won't work, because they are too long. EG/DC LCAs will fit the car, but the fork on EK dampers is too narrow. I do not know whether or not you can make them work by grinding down or swapping out the shock mount bushing. You'll want to find this out (try a search?).
For the fronts, you will need the forks from a '92+ Civic or '94+ Integra. They have a larger diameter ring than EF/DA to fit the larger diameter dampers.
Thanks for any help
</TD></TR></TABLE>I assume "suspension" means coilover assemblies.
97SS
Sep 21, 2007 04:03 AM
ironchef25
Jul 11, 2004 12:37 PM
HondaRcB
Mar 15, 2003 06:42 PM
gp93DX
14
Dec 1, 2001 11:52 AM
