SPC Camber Kit - Difference btw Ball Joint nd Anchor Adj?
It depends on the car and use. On the CRX used for racing (22.5" ride height) , for example, the adjustable ball joint can contact the inside on the wheel well. We use the 5/8 degree SPC camber correction eccentric to reduce the negative camber due to lowering. On other cars, the situation may be different.
LagunaSecaEG
11
Sep 3, 2006 07:01 AM
