Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block???
Old Jun 14, 2005 | 09:28 PM
D3U1LT's Avatar
Default Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block???
I Have a re-sleeved block and it was painted with a high temp/Strong paint the color black. Not really feelin it. I want the original cleanliness of the oem cast/aluminum color. how can I achieve this??
Old Jun 15, 2005 | 10:20 AM
D3U1LT's Avatar
Default Re: Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block??? (D3U1LT)
bump
Old Jun 15, 2005 | 10:29 AM
AutoXer's Avatar
Aircraft remover. Will strip just about anything.
Old Jun 15, 2005 | 10:34 AM
D3U1LT's Avatar
Default Re: Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block??? (AutoXer)
I used that on my last block it really did not get the job done. What about hot tank will this give results of the new block look?
Old Jun 15, 2005 | 10:56 AM
supaman111's Avatar
hard work man, thats a tough one. is the motor back in or still out?
sam
Old Jun 15, 2005 | 12:06 PM
D3U1LT's Avatar
Default Re: Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block??? (supaman111)
Motor is back and in my possesion. any other ideas?
Old Jun 15, 2005 | 01:58 PM
DohctorVtec's Avatar
Dude what I use to clean my block is brake cleaner airline remover is to much of a pain and if it gets on you man your gonna be sorry because it BURNS just get a can of Brake Cleaner spray it all over the block whipe it off with a shop rago r just hose it down keeps my block all shiny
Old Jun 15, 2005 | 02:30 PM
Ghetto Civic HX's Avatar
I love to drive
Default Re: Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block??? (DoctorVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorVtec &raquo;</TD></TR><TR><TD CLASS="quote">Dude what I use to clean my block is brake cleaner airline remover is to much of a pain and if it gets on you man your gonna be sorry because it BURNS just get a can of Brake Cleaner spray it all over the block whipe it off with a shop rago r just hose it down keeps my block all shiny</TD></TR></TABLE>
I don't think that'll get high temp paint off.
If it's still a bare block, I would find someone who "media" blasts. It's like small plastic pellets that can take off paint and finishes without damaging the base material.
Old Jun 15, 2005 | 02:38 PM
supaman111's Avatar
if the motor is still out of the car get it shot blasted and then get some very very light wet and dry to give it the new look. Must be careful where all the debry from shot blasting goes, don't want it in the motor!!!
Its hard to get that paint off man, whatever you use it has to be abrasive, can't use solvents as the paint is too tough.
sam
Modified by supaman111 at 12:19 AM 6/16/2005
Old Jun 15, 2005 | 07:14 PM
D3U1LT's Avatar
where do i get media/shot blast done and can i just hot tank it to clean all the debre
Old Jun 15, 2005 | 07:17 PM
Nova_Dust's Avatar
Have you thought about paint it silver with high heat paint?
Old Jun 15, 2005 | 08:03 PM
D3U1LT's Avatar
Default Re: (Nova_Dust)
ya but i dont want to paint on top of the black..
Old Jun 16, 2005 | 12:27 AM
supaman111's Avatar
yeh you can hot tank it to clean it after, you can get it shot blasted from an alloy wheel refurbing place, they usually shot blast the powder coating off wheels before they re-coat them.
sam
Old Jun 17, 2005 | 08:49 PM
umop-apisdn's Avatar
I suggest brake fluid or oven cleaner.
Old Jun 18, 2005 | 12:50 AM
D3U1LT's Avatar
Default Re: Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block??? (umop-apisdn)
to remove hight temp paint...?
Old Jun 18, 2005 | 01:02 AM
DumpedSi's Avatar
I used carb cleaner.. sprayed it on there and watched it melt away...
Old Jun 18, 2005 | 08:57 AM
D3U1LT's Avatar
Default Re: Sand Blast, Glass Peened, Abrasive.. ect how to strip black paint off my block??? (Slammed Si)
really, did it clean up nice?
Old Jul 30, 2005 | 06:39 PM
RHDintegXsi's Avatar
it may seem like it doesnt work too well...but if aircraft remover a lone sint getting the job done..hit it with a pressure washer..i did that with my engine bay that was painted over numberous times..whatever the aircraft reover didnt take off the pressure washer did..esp in those ahrd to get areas.
jdmkidd23
Paint and Body
Apr 22, 2008 12:32 PM
lude98SH
12
May 14, 2007 10:54 AM
grenthang
12
Oct 29, 2004 11:59 PM
Si Integra
May 15, 2004 06:08 PM
Chuckles
Mar 10, 2002 08:59 PM
