B16a2 into a EG civic..which axles?
Old Jun 14, 2005 | 07:46 PM
handa's Avatar
Default B16a2 into a EG civic..which axles?
I have a 93 Civic HB Si and I put a USDM B16a2 motor into it. The stock '00 B16a2 axles won't fit. I bought 94+ Integra axles and it was too long! I heard they are all the same axles anyways and they should work...but they didn't.
Which axles do I use? I'm stumped.
Old Jun 14, 2005 | 08:01 PM
1993sirhatch
Guest
Posts: n/a
Default Re: B16a2 into a EG civic..which axles? (handa)
any 94&up integra axles, and and 99-00 civic si axles, or 94-97 del sol vtec axles. all with the halfshafts if you dont have one already.
Daniel san's Avatar
shoul'nt you need the Delsol axel ?
Old Jun 14, 2005 | 08:02 PM
Daniel san's Avatar
Default Re: B16a2 into a EG civic..which axles? (1993sirhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sirhatch &raquo;</TD></TR><TR><TD CLASS="quote">any 94&up integra axles, and and 99-00 civic si axles, or 94-97 del sol vtec axles. all with the halfshafts if you dont have one already.</TD></TR></TABLE>
the B16 and B18 Axles are not the same
Old Jun 14, 2005 | 08:11 PM
HATCHingMN's Avatar
Default Re: B16a2 into a EG civic..which axles? (Daniel san)
all B series axles are the SAME
handa's Avatar
i'm using stock B16a2 halfshaft (intermediate shaft) and 94+ integra axles.
All B-series axles are the SAME....B16 & B18 axles are NOT THE SAME, which is it?
Old Jun 14, 2005 | 08:21 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">
All B-series axles are the SAME....B16 & B18 axles are NOT THE SAME, which is it?</TD></TR></TABLE>
get the 94+ 5 speed Integra axles,
del sol b16 axle, 99-00 SI axle
they all should fit into any B series motor
DC2 share the same chassis as the EG so 94-01 Integra is a better choice but all the above axle should fit cus they're the same
Old Jun 14, 2005 | 09:00 PM
handa's Avatar
Default Re: B16a2 into a EG civic..which axles? (HATCHingMN)
Thanks for confirming HATCHingMN. Maybe I'm not getting the axles in right or something, but I'll try it again, or i'll get some pics up.
SLPN H
Aug 14, 2008 08:52 AM
drumminforev
Dec 19, 2006 01:15 AM
NegativeXero
Aug 27, 2006 12:52 AM
eGeeHaTcH
Dec 5, 2004 06:51 AM
Sketch_hs
Feb 25, 2004 09:05 AM
