Honda Accord 92 Check engine light
Old Jun 14, 2005 | 07:03 PM
nguyennhatquang's Avatar
Default Honda Accord 92 Check engine light
I come from Viet Nam ,now I have Honda Accord 92 ,my problem is the check engine light alway on when I start my car ,it can"t off when the car run ,but when the car run ,i few no problem .Can you help me to turn off the check engine light ,and give me some picture to turn off this ,
thanks you
Old Jun 14, 2005 | 07:11 PM
xbn83's Avatar
Default Re: Honda Accord 92 Check engine light (nguyennhatquang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nguyennhatquang &raquo;</TD></TR><TR><TD CLASS="quote">I come from Viet Nam ,now I have Honda Accord 92 ,my problem is the check engine light alway on when I start my car ,it can"t off when the car run ,but when the car run ,i few no problem .Can you help me to turn off the check engine light ,and give me some picture to turn off this ,
thanks you</TD></TR></TABLE>
First of all, you don't need to say that you are from VN. I could tell by reading your name. Are you just out of the boat? Your writing is bad. You can turn the check engine light off, but it doesn't fix the problem. Whenever the check engine light on means you have some sort of problem with your car, and that is why it 's on. You turn if off will do no good. You have to fix the actual problem man. You turn it off now and it will come back later anyway. Check the check engine light code to see what problem you are having, then try to fix it. Don't do the F.O.B way. Don't tell me you don't know how to check for the code. Cha`o!
Old Jun 15, 2005 | 10:25 AM
asti's Avatar
Hi there Nguyen...If you just came to theis great country , welcome...And your writting is not bad, even if you are fresh here...At least ,you try your best...and I did the same...
About your engine code : On the passenger side ,right where the right wheel well is , it should be a small connector with 2 wires to it. I think that is a light blue color...If was not used before , it may have a little tape around it. Is usually the only one there... So once you find the connector, you would need to connect the 2 terminals... DO that with the car off. Once you connected the 2 terminals, turn the power on , and the check engine light would blink your code.
Once you know the code , that is going to help you fix the problem. Once you fix the problem , you can reset the computer by disconnecting the battery . Make sure that you know your stereo code ,if you need to disconect the battery...And that because it may have an anti theft code...
Good luck with your car. You may want to invest in a repair manual ,(Haynes or Helms ) if you are planning to work on your own car
Old Jun 15, 2005 | 06:15 PM
thank you ,my car has a problem about exhaust ,now , i already fix it ,thank you
Old Jun 15, 2005 | 06:50 PM
xbn83's Avatar
Off topic, where are you living? In the state?
Hondalina
Dec 13, 2010 02:39 PM
zak88lx
Jun 5, 2007 01:33 PM
djdelirius
Apr 24, 2005 10:59 PM
hw3679
Mar 31, 2004 05:27 PM
