A few ?'s about a caber kit... plz help if you can.
Old Jun 14, 2005 | 04:26 PM
Intense3.2's Avatar
Default A few ?'s about a caber kit... plz help if you can.
Heres the deal, Im about to buy this kit ---> http://www.autocarparts.com/part/288/7 has anyone had a problem with this kit? I drive a 94 accord coupe koni yellows (neuspeed editions) & neuspeed sport springs. Can anyone tell me a lil more about this kit? Thanks in advance. (yes i searched!!!) Are there any other kits you guys would recromend? what about this kit? http://www.ingallseng.com/parts/35595.htm
Modified by Intense2.2 at 5:37 PM 6/14/2005
Old Jun 14, 2005 | 06:42 PM
xbn83's Avatar
Default Re: A few ?'s about a caber kit... plz help if you can. (Intense2.2)
You should have alignment done first, then drive your car for a while see if the tires show a lot of wear. If yes, then buy camber kit, otherwise you dont need to. I have almost -2 on each wheel, and I had no camber kit. I ran like that for a while now, the tires show some wear but not a lot. Toe kills your tires, not camber. Camber wears too but not as much as toe.
Old Jun 14, 2005 | 06:59 PM
ef9wpb's Avatar
i kinda agree with the above, toe is the faster killer.. but i installed the kit first ... i got perfect camber but i do have some clearance issues.. upper A arm does bottom out in fender well when i hit a serious bump. but i have gone thru numerous sets of tires in the past so i finally just decided to go with the kit.
Old Jun 14, 2005 | 07:10 PM
Intense3.2's Avatar
Default Re: A few ?'s about a caber kit... plz help if you can. (ef9wpb)
Yeah i already got the alighnment.. and my tires are still being chewed up.What part of the tire does toe affect?
Old Jun 14, 2005 | 07:14 PM
xbn83's Avatar
Uneven wear, but if you have negative camber and toe then the inner of the tire.
Old Jun 14, 2005 | 07:24 PM
Intense3.2's Avatar
Default Re: A few ?'s about a caber kit... plz help if you can. (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Uneven wear, but if you have negative camber and toe then the inner of the tire.</TD></TR></TABLE>
Yeah the insides of my tires are getting eaten bad.
Old Jun 14, 2005 | 07:28 PM
xbn83's Avatar
When you did your alignment, did you get the specs sheet before and after the alignment? When I did mine, I asked for it so I could compare, and made sure they correct mine within the factory spec. I know a lot of places they do half *** job on alignment. Try to correct the toe as close to 0 as possible.
Old Jun 14, 2005 | 07:29 PM
ef9wpb's Avatar
get the kit then... the ball joint one i heard are pretty good too... i just didnt want to go the machine shop to have them pressed in.. but if you go with the first kind then make sure you make some room in your wheel well for the the upper a arm to move freely.
Old Jun 14, 2005 | 08:44 PM
Intense3.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9wpb &raquo;</TD></TR><TR><TD CLASS="quote">get the kit then... the ball joint one i heard are pretty good too... i just didnt want to go the machine shop to have them pressed in.. but if you go with the first kind then make sure you make some room in your wheel well for the the upper a arm to move freely. </TD></TR></TABLE>
Do you know if there are any issues with the ball joint kit? besides getting it in.. lol.
Old Jun 14, 2005 | 08:50 PM
xbn83's Avatar
This is from my experience, I put ball joint camber kit in the front for '96 accord. It corrected all the camber but one of the wheel stick outside the fender more than the other. I still had a lot of toe out even after I got the alignment done. I don't know if it is just me or not. Just sharing my experience.
Old Jun 14, 2005 | 10:06 PM
Intense3.2's Avatar
Im about to say **** it... im so sick of this lowering **** with my car.. eating through tires n ****. Thanks for the help so far guys.
civicracer12381
Apr 25, 2004 05:35 PM
IloveNewt
May 5, 2003 10:24 AM
Ski2001
Dec 18, 2002 03:27 PM
VTECTIME
Sep 11, 2002 04:04 AM
