A/C compressor / bracket question
Old Jun 14, 2005 | 04:02 PM
RCautoworks's Avatar
Default A/C compressor / bracket question
I have a 94 civic with a jdm type R engine in there. My question is, the compressor from the Type R is set up differently, the holes are side ways instead of up and down.
So my question is, what bracket and compressor will work ? I was told a gsr, but that is making no sense to me
Old Jun 14, 2005 | 05:09 PM
Default Re: A/C compressor / bracket question (90blackcrx)
Someone has to know, need this info a.s.a.p
Old Jun 15, 2005 | 09:58 AM
Ok then how about this, will a D series bracket or compressor fit onto a b series engine ?
Old Jun 15, 2005 | 10:13 AM
dwnthehatch's Avatar
Keep your d series compressor and use a del sol dohc vtec or crv ac bracket.
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
Old Jun 15, 2005 | 07:09 PM
93Civac's Avatar
Go with the crv bracket. Its only about $65 from Honda and the del sol bracket is about $115.
Old Jun 15, 2005 | 07:52 PM
civicsisi's Avatar
Default Re: (93Civac)
Just curious, are both brackets the identical? or does it matter what engine you are running....... b18(b,c) vs b16(a,b)
Old Jun 16, 2005 | 07:47 AM
Default Re: A/C compressor / bracket question (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">Keep your d series compressor and use a del sol dohc vtec or crv ac bracket.
38930-P54-000 Del Sol Bracket</TD></TR></TABLE>
The del sol bracket is from the dohc engine right
Old Jun 16, 2005 | 01:56 PM
civicsisi's Avatar
yes you need the ac bracket from the DOHC delsol.
Anyone answer my question?? i was wondering if the crv bracket is identical to teh delsol one, from what i hear they will both work but i heard somewhere that the crv one works for the b18's but not the b16's? i have only seen the p-54 bracket.
Old Jun 16, 2005 | 07:06 PM
93Civac's Avatar
I bought the crv bracket to use on my B16. It bolts on perfectly to the block. I havent put the swap in my car yet but ill definetly find out in a few weeks whether or not iut works.
Old Jun 18, 2005 | 11:32 PM
94hatchling's Avatar
has any used the crv bracket on their b16 swap on a 92-95? i see the guy above me has it bolted to the block, but i would like some more comfirmation that it bolts to the stock d-series compressor. just wanna make sure and do all my research before i purchase anything.
Old Jul 18, 2005 | 02:35 AM
jEE's Avatar
jEE
Default Re: (94hatchling)
bump for this ..
Old Jul 18, 2005 | 08:53 AM
Default Re: (jEE)
Not sure what bracket the customer got, but I know the compressor from the sohc will work, you just need the bolts because there longer then the dohc bolts
Old Jul 19, 2005 | 02:54 PM
93Civac's Avatar
Crv bracket does work, i just finished putting everythin in my car and it worked perfectly. Like 90blackcrx said, use the bolts for the d series compressor cause they are longer.
Old Jul 20, 2005 | 04:10 PM
Ok I just had the customer email me. I basically bolted the a/c bracket on the engine but I could not bolt the compressor up because the bolts are to short.
So anyways the other mechanic is telling him the compressor will not bolt up to the bracket.
Supposdly the bracket is from a del sol vtec engine
And the compressor is from a sohc engine
I'm thinking the bracket might be from the sohc del sol engine, but if it was, I'm not sure it would even bolt up to a b series engine.
Something seems odd.
Old Jul 20, 2005 | 05:01 PM
TK-4004's Avatar
Default Re: (90blackcrx)
im pretty sure that if you use the crv bracket on a b16.....then you wont be able to use power steering. i dont think this is a problem with the b18.
Old Jul 20, 2005 | 05:07 PM
92b16vx's Avatar
The D series 92-95 Civic compressor, will 100% bolt up to these parts, they are exactly the same, other than the number...
P54 bracket/D series compressor/B16A
Old Jul 20, 2005 | 05:09 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac &raquo;</TD></TR><TR><TD CLASS="quote">Go with the crv bracket. Its only about $65 from Honda and the del sol bracket is about $115.</TD></TR></TABLE>
CRV bracket works perfect. Why would anyone buy the Sol bracket for $115
Old Jul 20, 2005 | 05:11 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking the bracket might be from the sohc del sol engine, but if it was, I'm not sure it would even bolt up to a b series engine.
Something seems odd.</TD></TR></TABLE>
It has to be from the VTEC model as in the one that came with the b16a3. A bracket out of a SOHC VTEC Sol will not work. Just get the CRV bracket.
Old Jul 20, 2005 | 05:14 PM
92b16vx's Avatar
$60 plus shipping from hondaautomotiveparts.com
Old Jul 20, 2005 | 05:15 PM
92b16vx's Avatar
Default Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">It has to be from the VTEC model as in the one that came with the b16a3. A bracket out of a SOHC VTEC Sol will not work. Just get the CRV bracket.</TD></TR></TABLE>
And it has to be the 94-95 DelSol vtec model, the later ones have a P30 which does not work.
Old Jul 20, 2005 | 05:41 PM
BROKE.eg's Avatar
Default Re: (92b16vx)
you can use the gsr or type r ac bracket...but then only two bolt holes will line up on the compressor. ive had a few people do this now problems.
Old Jul 20, 2005 | 06:11 PM
The customer already ordered it, the bracket bolts to the engine, but the compressor will not bolt up ( atleast thats what the other mechanic said ) . He had to take it some where cause he needed a closer mechanice, anyways here is what he just said.
"I know what happen.
this is ******* great. the Del Sol (vtec) bracket from 93-95 is different from 96-97, and I bought the one from 96-97. crap."
So I'm still struggling to figure out what engine it came from, the sohc del sol engine ? If so I did not think that would of even bolted up to a b series engine
Old Jul 20, 2005 | 06:18 PM
92b16vx's Avatar
Default Re: (BROKE.eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKE.eg &raquo;</TD></TR><TR><TD CLASS="quote">you can use the gsr or type r ac bracket...but then only two bolt holes will line up on the compressor. ive had a few people do this now problems.</TD></TR></TABLE>
Maybe they haven't had problems yet, but they will. I know this because I tried to cheap out and use the wrong one. The two bolts broke, and the compressor came off, one of hte hoses landed on the header and expelled refrigerant all over the highway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">The customer already ordered it, the bracket bolts to the engine, but the compressor will not bolt up ( atleast thats what the other mechanic said ) . He had to take it some where cause he needed a closer mechanice, anyways here is what he just said.
So I'm still struggling to figure out what engine it came from, the sohc del sol engine ? If so I did not think that would of even bolted up to a b series engine</TD></TR></TABLE>
Right, 92-95 D compressor, needs hte 94-95 DelSol vtec P54 bracket, or the CRV one to mount on a B series. The later P30 fits the motor, but the D series compressor will not bolt to it.
Old Jul 23, 2005 | 09:39 PM
The crv bracket works on b16 motors with the d series compressor ONLY if you do not have power steering.
Old Jul 25, 2005 | 03:58 PM
gato5254's Avatar
good looking
supastardavid
May 23, 2008 09:14 PM
powderb18b
10
Jun 21, 2007 07:03 AM
quik sol
Jul 30, 2006 11:34 PM
redsled00
Oct 14, 2005 06:39 PM
Todapwr
14
Mar 5, 2004 09:49 PM
