car loos power after changing gear
I got 2000 civic EX with 60000 mles. When car change gear acceleration becomes really slow until RPM hits around 3500. It seems like car is loosing power when gear changes.
So far I have done these thing
Changed spark plugs and wires
Check timing
I would appreciated any help
Check timing
Is this an automatic I'm assuming? The gear ratios become smaller the higher up you go, so a loss of multiplied torque at the wheels is something you should expect from a physics standpoint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Is this an automatic I'm assuming? The gear ratios become smaller the higher up you go, so a loss of multiplied torque at the wheels is something you should expect from a physics standpoint.</TD></TR></TABLE>
Yes it is auto.
But thing is I got another 4dr civic same year and that car runs grate. I know there is some problem with this car.
Yes it is auto.
Jaydeep
Sep 3, 2003 12:48 PM
cr-x si
Nov 20, 2002 07:17 PM
