Sweet smell from exhaust
Old Jun 14, 2005 | 11:39 AM
h22pwr's Avatar
Default Sweet smell from exhaust
My friend says that when he's behind me he can faintly smell something sweet in my exhaust when I'm in the upper rev ranges. Not just when I'm in VTEC, it seems like its doing it at 4500rpm and higher. Even when I'm in VTEC there is never visible smoke from the exhaust. Any ideas what it is, is it normal?
Old Jun 14, 2005 | 11:52 AM
vinuneuro's Avatar
Default Re: Sweet smell from exhaust (h22pwr)
sweet smell is usually coolant. or ur feeding ur engine cotton candy.
Old Jun 14, 2005 | 11:58 AM
83Rabbit's Avatar
Default Re: Sweet smell from exhaust (vinuneuro)
hehe byebye headgasket
Ive seen plenty coolant probs that dont smoke. You could have a problem in your coolant system thats leaking because of coolant pressure at high RPMs, check for leaking coolant upfront. If nothings leaking in your bay, your probably burning a very light bit of coolant through your motor. Probably a headgasket or very minor crack in your block. Check compression.
Old Jun 14, 2005 | 12:02 PM
PrecisionH23a's Avatar
Default Re: Sweet smell from exhaust (83Rabbit)
If your plugs have a greenish hue to them.... it's probably the HG as already stated previously. If they are also a bit white that is a good indication of the HG as well.
Old Jun 14, 2005 | 12:04 PM
83Rabbit's Avatar
oh and monitor your coolant level like a hawk.
Old Jun 14, 2005 | 12:14 PM
VTECRaZeR's Avatar
Yea dude without a doubt....I will have to say you have very bad news, that head gasket its going out man.
Take care of that puppy asap before you get stranded with worst things than that.
Old Jun 14, 2005 | 02:32 PM
clemsoncb7's Avatar
Default Re: Sweet smell from exhaust (VTECRaZeR)
^^^^ Yes, do not get stranded. it sucks. I got stranded with a blown headgasket after boosting and it was a shitty day
Old Jun 14, 2005 | 07:05 PM
h22pwr's Avatar
Ok, so should there not be any smell from the exhaust, except in vtec. It smells like burnt fuel to me.
Old Jun 14, 2005 | 07:54 PM
fbodymechanic's Avatar
Default Re: (h22pwr)
it's a good thing doing a head gasket is easy in a honda. . . try in a v8. . . talk about a lot of work lol. good luck should only take a couple hours. we did it in my friend's crx, he has a zc motor in it, like 3 hours to have it off, cleaned back on and running again! could never do that in a camaro. . .
96honda_EK
Sep 15, 2010 01:07 PM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
Ozne99
May 27, 2008 08:36 PM
NoVALude
Dec 31, 2006 12:40 AM
akaEsCo01
13
Dec 8, 2004 01:27 PM
