what do you guys think about this?
Old Feb 11, 2002 | 01:40 AM
2 litre EG's Avatar
Default what do you guys think about this?
what do you think this motor set up will hit???and what do you think the comp is with ctr piston???11:1?? 12:1??
B16a block
Civic type R pistons
civic type R rods
b16 head
civic type R cams
crower valvetrian
crower valves (16)
crower valve springs
crower Ti retainer
cam gears??
ECU
hondata stage 4
RC injectors 280
itr 4-2-1 header
Old Feb 11, 2002 | 07:21 AM
Spade's Avatar
Default Re: what do you guys think about this? (allm0t0rsir)
B16a block -------------------- You really want torque for all motor (if you already own the B16, sleeve and bore the SOB.)
Civic type R pistons ----------
civic type R rods -------------- Forged I or H beams (almost same price)
b16 head ---------------------- Good flowing (Type R without the port)
civic type R cams -------------/ Research the CTR/ITR cams(the exhaust is the same cam)
crower valvetrian -------------N/O (no opinion)
crower valves (16) ----------- not needed unless you port and polish the head.
crower valve springs --------- What is your redline goal (ITR springs good for 8400)
crower Ti retainer ------------ http://www.portflow.com (have them do you head work)
cam gears?? ------------------N/O haven't researched these enought to know who is good and who isn't......some people have had there gears slip.....not good.
ECU
hondata stage 4 -------------!!!! Why pay 1200 bux for something when a VAFC does close to the same thing at 300!!!
RC injectors 280------------- Fully research horsepower needs before you purchase large injectors. (people have pushed 200+ whp on stock injectors)
itr 4-2-1 header--------------- JDM 4-1 ITR header.
EDIT: and to answer your compression ratio question. http://www.bojangz.com/calculator/
[Modified by Spade, 8:23 AM 2/11/2002]
Old Feb 11, 2002 | 10:04 AM
BoM's Avatar
BoM
That looked Fun for you spade...i'll give my opinion on it too.
B16a block - like the Rod/Stroke ratio, hate the displacement. You can get around it...
Civic type R pistons - Good! OEM parts!
civic type R rods - not really needed stock is good.
b16 head - PORTFLOW headwork
civic type R cams - works well with the b16!! ITR ones Cheaper.
crower valvetrian - PORTFLOW as well, have them resemble your head with them.
crower valves (16) - along with ferrea valves +.5; not really needed but it'll help.
crower Ti retainer - Portflow as well.
cam gears - gears anything other than aem; TODA's are very popular, SKunk2 ect.
ECU - either get a chipped ecu or the hondata...
hondata stage 4 - not needed at all...stage 2 is fine and have some one else tune it.
RC injectors 280 - its fine
itr 4-2-1 header - nonono a nono get either the JDM 4-1 or another; JUN, SPOON ect....
Hiflow CAT - carsound ect....
APexi N1 - or any straight through exhaust.
ITR intake manifold
OR instead of building your whole engine. Build the bottom end.
Take a b20 block add pistons (12:1 CR) and rods, GSR girdle
plant it with the SI head with ITR cams, and hope u dyno 200+whp
like hxguy
Old Feb 11, 2002 | 10:59 AM
Spade's Avatar
Default Re: what do you guys think about this? (BoM)
Exactly. In all actuallity we would like to know what you are trying to achieve with your engine/performance. Once you share that, we can get more specific when it comes to the engine.
Old Feb 12, 2002 | 12:00 AM
2 litre EG's Avatar
iam looking to hit about 13.00 to 12.80sec all motor daliy driven 91 pumpgas
lessDXHB
15
Aug 27, 2005 02:14 PM
.derf.
Oct 15, 2003 07:50 AM
pushr0djunk
Feb 15, 2003 02:02 PM
not so civic
Dec 18, 2002 09:31 PM
typeSwarrior
Feb 7, 2002 02:45 PM
