Suspension & Brakes Theory, alignment, spring rates....
where is th spring rate list
Old Jun 14, 2005 | 11:01 AM
kevpotts's Avatar
Default where is th spring rate list
hey, i know ive seen a "master" list with all kinds of spring rates on it in here somewhere. Ive searched and searched but i cant find it again, can anybody link me? sorry for the worthless thread, i just wanna take a gander at my spring options.
Old Jun 29, 2005 | 07:37 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: where is th spring rate list (kevpotts)
http://www.jimmmmmmmah.com/Ins...s.htm
Old Jun 30, 2005 | 05:18 AM
kevpotts's Avatar
Default Re: where is th spring rate list (mr.GREEN)
thanks man. i found some on team-integra.com but the numbers arent the same at all... like not even kinda close. i don tknow who to believe!@!@#%$34298y w3qp9toha
Old Jun 30, 2005 | 05:30 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevpotts &raquo;</TD></TR><TR><TD CLASS="quote">thanks man. i found some on team-integra.com but the numbers arent the same at all... like not even kinda close. i don tknow who to believe!@!@#%$34298y w3qp9toha</TD></TR></TABLE>
Well, what exactly is it you'd like to know? A certain brand that you're looking into or something?
The problem with springrate ratings is that most replacement springs are progressive, and therefore can be reported differently by different sources.
Old Jun 30, 2005 | 05:47 AM
kevpotts's Avatar
Default Re: where is th spring rate list (AutoXer)
well im not looking for anything specific, im just looking at the numbers to help me decide which spring i would like to buy. heres a link to the teamintegra list.
http://www.team-integra.net/fo...ion=1
also what are the pros/cons for progressive compared to linear springs? itr front springs are linear i think... is linear more responsive? any input is greatly appreciated
Old Jun 30, 2005 | 07:04 AM
IN VTEC's Avatar
You're probably referring to this:
http://mypage.iu.edu/~bchang/P....html
I created that thing so long ago. I don't even know if it's still applicable.
Last modified: 17-Apr-2002 01:35
Personal preference-wise, I cannot stand driving on progressive-rate springs in the front. It makes the car feel like mush, but it does have the advantage of not unsettling the car so much when you hit bumps while daily driving, even if you are driving a little hard. Holes and dips are the same for either. They suck.
You'll never be happy until you get a set of fully-adjustable coilover assy's. I went through the same thing three years ago. Now I have Tein Type RE's and ITR springs/shocks....couldn't be happier and I haven't changed the set up (excepting spring rates on RE's) in the last two and half years.
Old Jun 30, 2005 | 07:10 AM
AutoXer's Avatar
Well, one list was for civics, and the other is for integras, so they will be different. Since I'm assuming you're looking for your integra, I'd go with the team integra list; and use it as a 'this is stiffer than that' rather than a hard and fast number. If you want a specific springrate, go with GC sleves.
Progressive rate springs have verying rates as they compress. This allows a softer tuned ride by having a low initial rate that increases as the spring compresses. That way it's not a stiff jolt on potholes or other irregularities.
Old Jun 30, 2005 | 07:36 AM
kevpotts's Avatar
well my car will never be autox'ed or tracked, its just a daily driver that i like having fun with. right now im considering the sportlines or the h&r sports on agx shocks. yay or nay
UltimX
Suspension & Brakes
Aug 30, 2005 08:37 AM
mountaindewguy
Suspension & Brakes
Feb 24, 2005 02:17 PM
E V I A N
Dec 16, 2004 09:08 AM
DIRep972
Jan 5, 2004 05:02 AM
MechEng
Jun 4, 2003 01:04 PM
