AC problem with my 92 lude
Old Jun 14, 2005 | 10:11 AM
HONDA-2NR's Avatar
Default AC problem with my 92 lude
ok, yesterday i drove around for about 30-45 minutes with my AC on and no problems what so ever, it was nice and cold . this morning i went out to my car and let it warm for like 5-10 minutes then i took it out to drive. when i was out i decided to turn my AC on. So i then turned it on and when i turned it on my AC and rear window defrost both came on. so i tried to push the window defrost button to turn it off but it wont go off!! so i then turned my AC off and then my rear window defrost went off. so now whenever i turn my AC on my rear window defrost is always on, but thats not the worst part. now my AC is only blowing warm/hot air out when yesterday it was nice and cold? my AC might need recharging but that dosent explain why the rear window defrost comes on when i push the AC on.
SOMEONE PLEASE HELP ME ITS 95 DEGREES OUTSIDE!!!!!!
Old Jun 14, 2005 | 10:14 AM
VisPreludeVtec's Avatar
Default Re: AC problem with my 92 lude (HONDA-2NR)
sounds like the connections on your circuit board might be going bad. typical thing to happen on 4th gen climate controls
Old Jun 14, 2005 | 10:25 AM
HONDA-2NR's Avatar
Default Re: AC problem with my 92 lude (VisPreludeVtec)
i tried it now with the key turned to the Accessory part and the rear window defrost light goes off but it still blows hot air!! but still when i turn the car on both still come one??
anyone else have any suggestions
Old Jun 14, 2005 | 11:03 AM
mine will blow hot air sometimes. press AC button in and out a couple times and see it the AC works again. it works for me sometimes
Demon R
May 23, 2004 10:46 PM
Token Blk Guy
Jun 8, 2003 06:00 PM
