Quick ? about cam/ignition timing HELP!
Old Jun 14, 2005 | 09:53 AM
fast2camciv's Avatar
Default Quick ? about cam/ignition timing HELP!
i mill my head .040 (SOHC Vtec d16Z6) i know that i need to advance my cam roughly 3-3.5 degrees.
my question is how do i set up my ignition timing? do i set my crank and gear to 0' and then set my dizzy to 16' and then advance my gear 3 degrees?
-or-
do i set the crank at 0, move the cam gear to advance 3' and align to the head (wich is now zero) and then set my dizzy to 16 degrees?
in short what is the sequence of events that i need to do in order to get my ignition/cam timing back to stock with a head that is milled .040????
Old Jun 14, 2005 | 04:21 PM
Rocket's Avatar
Default Re: Quick ? about cam/ignition timing HELP! (fast2camciv)
You first need to verify that 1 tick mark on the gear equals 1 crank degree or 2 crank degrees. It's usually one or the other.
Old Jun 15, 2005 | 05:34 AM
Default Re: Quick ? about cam/ignition timing HELP! (Rocket)
its an aem gear the old 3 bolt style. im not sure i assumed it was 1:1 is that the case?
Old Jun 15, 2005 | 06:00 AM
b19coupe's Avatar
You use a timing light to set your ignition timing. No matter what you have done with your cam timing, the timing light will show you your actual ignition advance.
#Leo#
May 20, 2010 11:17 PM
johnwohl
May 17, 2009 12:27 PM
hondapwr
Jan 4, 2008 09:33 AM
