what to replace along with waterpump?
Old Jun 14, 2005 | 09:29 AM
notguilty411's Avatar
Default what to replace along with waterpump?
im pretty sure my waterpump has ceised (sp?) up in my civic.. (98 hx d16y5)
and its been making my car over heat pretty bad, its got 123k and i know there are some things that need replaced..
so my question is along with the waterpump what all else should i replace,
and i want to do everything at once since i need this car to get be back and forth to college for the next couple years..
so what would you guys reccomend along with the waterpump
Old Jun 14, 2005 | 09:30 AM
Deemeetree's Avatar
Electrician
Timing belt. OEM Honda
Thermostat. OEM Honda
Coolant. Prestone 50/50
Old Jun 14, 2005 | 09:38 AM
Lee_Delso's Avatar
Default Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Timing belt. OEM Honda
Coolant. Prestone 50/50</TD></TR></TABLE>
+Timming belt tensioner...then you might as well do all your belts if it hasn't been done and at the same time check your valve clearence.
Old Jun 14, 2005 | 10:42 AM
how do i go about checking the valve clearance??
and i was considering getting a compression test done as well, because im afraid my head gasket is close to going from all the over heating its been doing
any thing else to check?
Old Jun 14, 2005 | 11:00 AM
Deemeetree's Avatar
Electrician
Might as well replace the headgasket while you're at it then.
Head gasket
Timing belt
Thermostat
Timing belt tensioner
Coolant
Then, you'll be set in the cooling and keeping your head on department.
Old Jun 14, 2005 | 11:08 AM
solareclipseauto's Avatar
everything that was previously mentioned and youll be good
alright.. what about the radiator? do they go bad after a period of time
or shouldnt i worry about it
Old Jun 14, 2005 | 11:21 AM
Default Re: (notguilty411)
just flush it and you will be fine
tanked_honda
Honda Civic (2001 - 2005)
Feb 16, 2019 12:29 PM
nskbob
Apr 15, 2013 06:37 AM
Sik Eg
15
Apr 29, 2012 06:34 PM
redDAinteg
Jul 20, 2007 09:40 AM
vinuneuro
Aug 10, 2005 03:07 PM
