alternative to stiffer drag springs
i was thinking of a bar that connects the rear LCA's at the middle hole(bottom of the strut) with a shock absorber in the middle.
in my mind it basically does the same as heavier drag springs, but you dont have to swap your whole suspension everytime you want to use it...
what do you think.
what do you think.
ive done over 100 spring/strut installs, and its no problem.
i am just thinking of ideas here...and wondering if it would work.
you cant disagree that this wouldnt be simpler...
