Fuel Injector Size?
I plan on building my B18C1 for turbo, running about 10-12 PSI(maybe, Myabe a little more)but i was wondering what would be a good fuel injector size to use on my motor?will i get more power etc. w/ larger fuel injectors, even if i dont NEED ones that big, or will this cause a fuel problem?
You'll need s200 that should be sufficient for what your doing. 440's will be good enough.
You have to tune everything together, you cant expect the injectors to really work the correct way until then.
JustAnotherHonda
Mar 9, 2003 09:15 PM
