type s piston clearance
Old Jun 14, 2005 | 04:48 AM
boostinh22
Guest
Posts: n/a
Default type s piston clearance
i'm wondering if anyone who's got type s pistons clayed their motor before assembly. i'm just trying to find out if type s pistons would clear with ferrea stock sized valves and stock h22a4 cams. thanks guys.
Old Jun 14, 2005 | 06:12 AM
VTECRaZeR's Avatar
Default Re: type s piston clearance (waterboy683)
If I'm reading this right, it should clear with no problems. It's all stock size.
Old Jun 14, 2005 | 06:23 AM
VSBB6's Avatar
Default Re: type s piston clearance (VTECRaZeR)
what about Type S pistons with flat valves, would that clear?
Old Jun 14, 2005 | 06:35 AM
VTECRaZeR's Avatar
Default Re: type s piston clearance (VSBB6)
stock size flat valves?
If they are stock size flat valves I'm pretty sure it shouldn't be a problem anyway, they are still stock size, the only thing that changed is that the valve is flat.
Modified by VTECRaZeR at 7:49 AM 6/14/2005
Old Jun 14, 2005 | 07:06 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECRaZeR &raquo;</TD></TR><TR><TD CLASS="quote">stock size flat valves?
Modified by VTECRaZeR at 7:49 AM 6/14/2005</TD></TR></TABLE>
Yeah. Unless they started to make dome valves now?
Old Jun 14, 2005 | 07:11 AM
VTECRaZeR's Avatar
Default Re: type s piston clearance (cpforyou)
I think what he meant is like stock valves have a lil dome shaped cut on the valve.
Old Jun 14, 2005 | 07:31 AM
boostinh22
Guest
Posts: n/a
thanks guys. anyone else have input?
Old Jun 14, 2005 | 07:33 AM
cpforyou's Avatar
More serious response here:
It should clear. They are stocked size valves.
Old Jun 14, 2005 | 09:05 AM
SPEEDQUEST INC.'s Avatar
I have type S pistons on an h23 with an h22 head, the piston stick out of the deck a little and the dome comes out a lot. I used a thicker cometic head gasket cause I didnt like to see the pistons sticking out of the deck . I have a Pure tunning valve train and stage 3 crower cams. 1200 miles and the car runs fine so far, I was always scared of the same thing, so i got the cometic gasket, but not sure if it's nessesary, I just did it to be safe..
Old Jun 14, 2005 | 09:28 AM
Honda318dx's Avatar
Default Re: type s piston clearance (SkunkEk)
Why were the pistons sticking out of the deck? Did you use H22 rods?
Old Jun 14, 2005 | 09:31 AM
Default Re: type s piston clearance (Honda318dx)
I used h23 crank and h23 rods... i have no Idea why they stuck out, they just did, i haven't asked them yet.
derilict
May 19, 2006 02:37 PM
Squrtin DC2
15
Apr 22, 2006 06:35 AM
iakona
Mar 11, 2005 12:37 PM
iakona
Mar 9, 2005 01:48 PM
JBk24crx
Jul 2, 2004 05:50 PM
