Prospeed H22a 4-1 Merge Collector Header - Jet Hot Coated
Old Jun 13, 2005 | 10:14 PM
The Birdman's Avatar
Default Prospeed H22a 4-1 Merge Collector Header - Jet Hot Coated
I'm selling my prospeed 4-1 header with the 2.5" merge collector. The header is coated inside and out very nicely by JET HOT's sterling based coating. It has a flex pipe and straight pipe welded onto it which are also coated. There is also a flange welded on the end that bolts up to the prelude exhaust. It came out of a 4th gen. The coating looks real nice and the header has only been used for about 4 months. The coating keeps the temps under the hood down too. I spent about $1,000 on this setup. Make me an offer. PM me for any more details.
By the way this header will fit a 5th gen with the same mods done to a 4th gen, and it will fit the 92-95 civic with NO problems.
Let me know
Modified by jd3jdm at 2:08 PM 7/13/2005
Old Jun 14, 2005 | 02:09 AM
BJOnewiper's Avatar
it's a beut!
Old Jun 15, 2005 | 09:07 AM
Default Re: (bjo)
thanks
Old Jun 17, 2005 | 07:39 AM
Default Re: (jd3jdm)
bump.....
Old Jun 17, 2005 | 08:36 AM
cre18's Avatar
wow, siic header, bump for you
Old Jun 21, 2005 | 06:00 PM
Default Re: (cre18)
bump...
Old Jun 24, 2005 | 09:59 PM
WickedSol's Avatar
you had bought the mild steel version or the stainless?
Old Jun 25, 2005 | 04:44 PM
Default Re: (SpdImge415)
it's the mild steel but it's the newer 16 gauge version not the old version that cracks on everyone.
Old Jun 26, 2005 | 09:13 AM
bump for the day
Old Jun 28, 2005 | 03:01 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jd3jdm &raquo;</TD></TR><TR><TD CLASS="quote">it's the mild steel but it's the newer 16 gauge version not the old version that cracks on everyone.</TD></TR></TABLE>
Does this one fit Preludes w/o modifications to the crossmember?
Old Jun 28, 2005 | 04:50 PM
Default Re: (cpforyou)
^^no... there is a little hammering to do in the spot right in front of the block. Not too big of a deal... I had mine cut out a little bit to keep the overall shape the same but it really didn't require too much work.
Old Jun 30, 2005 | 07:22 AM
bump
Old Jul 11, 2005 | 06:58 AM
Blanket Jackson's Avatar
Will it fit an h22 92-95 hatch?
Old Jul 11, 2005 | 07:54 AM
Default Re: (SlowSpyder)
yeah, thats the car this header was made to fit into.
Old Jul 24, 2005 | 10:44 PM
bump...
Old Jul 29, 2005 | 10:10 AM
bump...
Old Aug 1, 2005 | 08:23 PM
bump
Old Aug 6, 2005 | 04:03 PM
bump
Old Aug 7, 2005 | 12:34 PM
Carolina Fried Rice's Avatar
Where are you located in NC and whats the lowest you'll go on this header? thanks man LMK
Old Aug 8, 2005 | 10:43 PM
Default Re: (TSAF22B1)
pm'ed
Old Aug 10, 2005 | 08:02 AM
bump
Old Aug 13, 2005 | 01:11 PM
bump
Old Aug 14, 2005 | 02:31 PM
99exd16y8's Avatar
interested! pm'ed
Old Aug 14, 2005 | 02:34 PM
Bonez21's Avatar
Default Re: (99exd16y8)
dammit another reason to get a H22 dammit decisions decisions
Old Aug 14, 2005 | 02:49 PM
Default Re: (Bonez21)
well here's another reason to get an h22.
That header and a good intake setup (im and throttle body).... and you've hit 200whp on a stock internals engine!!
-try that with a b-series
