H22; Auto to H23 Manual Tensioner Help
Old Jun 13, 2005 | 05:41 PM
BB6-213's Avatar
Default H22; Auto to H23 Manual Tensioner Help
I just did the auto to manual tining belt tensioner conversion, and I noticed that the Tining belt tensioner and the balancer belt roller pulley? (dont know the name) are going to rub together, and I know this isnt good. The thing is that I have the balancing shafts removed and I dont need that on there, and I was wondering if I could just make some kind of spacer to replace that roller pulley, if not, what can I do to resolve this, washers maybe? thanks guy's.
Old Jun 13, 2005 | 10:45 PM
SKDRCR's Avatar
Default Re: H22; Auto to H23 Manual Tensioner Help (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">I just did the auto to manual tining belt tensioner conversion, and I noticed that the Tining belt tensioner and the balancer belt roller pulley? (dont know the name) are going to rub together, and I know this isnt good. The thing is that I have the balancing shafts removed and I dont need that on there, and I was wondering if I could just make some kind of spacer to replace that roller pulley, if not, what can I do to resolve this, washers maybe? thanks guy's.</TD></TR></TABLE>
Go through the thread on collectiveracing.net.
It gives the part # for the 3mm washer you're supposed to use.
Old Jun 16, 2005 | 03:42 PM
BB6-213's Avatar
I have the 3mm washer, but it still looks like its going to rub any more suggestions?
Old Jun 16, 2005 | 06:08 PM
boostlude's Avatar
Default Re: (BB6-213)
If you go on PO 71dsp has a pict of a spacer he made to remove the balancer belt pulley. Just space it out with washers it basically is just a spacer now or do like he did and get/make a spacer. i left my balancer belt on and spaced it with washers and it has been working fine just make sure that they are not tool big and limit the travel up and down of the timing belt pulley.
Old Jun 16, 2005 | 06:56 PM
crdcz03's Avatar
Fortune Cookie Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">I have the 3mm washer, but it still looks like its going to rub any more suggestions?</TD></TR></TABLE>
you say it looks like its going to rub... is it touching the other tensioner or not? if its not then i doubt itll rub
Old Jun 16, 2005 | 08:37 PM
h8trix's Avatar
I had the same problem, but I ordered the h23 part where you don't need the washer. It only rubs when I rotate the engine counter clockwise, if I go clockwise its fine.
whatever210
Mar 5, 2008 12:14 PM
mattmw88
Oct 18, 2006 04:40 AM
patastinky
Mar 16, 2005 12:41 PM
enikdawg
Jun 26, 2003 06:13 AM
Jonathan_ED3
Apr 15, 2003 04:09 PM
