y8 manifold in my a6?
Old Jun 13, 2005 | 04:53 PM
remymar's Avatar
Default y8 manifold in my a6?
Im installing a complete y8 intake manifold and throttle body on my obd0 a6, do I transfer my a6 dashpot into the y8 throttle body or just leave it off. The y8 throttle body does not use a dashpot. Thanks in advance.
Old Jun 13, 2005 | 04:57 PM
Kryogen's Avatar
just leave it off, and another thing for you with the Y8 IM, You gotta mount your IAT either in the manifold....requires tap and die set, or drill a hole in your short ram or CAI pipe for it and extend the wires.
Old Jun 13, 2005 | 06:37 PM
vegaskurt's Avatar
Default Re: (Kryogen)
just do what I did. Take the IAT, drill a hole in your air intake tube to fit it. Then just use two self tapping screws to hold it in place. I also used a little bit of black silicon sealant to seal it.
I diddnt even hookup the dashpot that is on the y8 fuel rail. Just cap it off.
Good luck, you'll like the y8 intake.
Old Jun 13, 2005 | 08:18 PM
remymar's Avatar
How did you lengthen your fuel return hose I notice the y8 fpr is on the opposite side.
Old Jun 13, 2005 | 08:20 PM
dr_latino999's Avatar
Default Re: (remymar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remymar &raquo;</TD></TR><TR><TD CLASS="quote">How did you lengthen your fuel return hose I notice the y8 fpr is on the opposite side.</TD></TR></TABLE> Autozone, fuel pressure rated line, possible fitting to connect, at the end.
Old Jun 13, 2005 | 08:22 PM
remymar's Avatar
Can I also use my a6 fuel line that connects to the fuel rail is there anything else I need to modify. thanks again guys I want to get my car running asap.
Old Jun 13, 2005 | 09:03 PM
eda6's Avatar
It should reach if you reroute it behind the master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remymar &raquo;</TD></TR><TR><TD CLASS="quote">Can I also use my a6 fuel line that connects to the fuel rail</TD></TR></TABLE>
Yes
Modified by eda6 at 11:36 PM 6/13/2005
_HANS
18
Jun 13, 2024 09:49 PM
kkim
12
Jul 5, 2005 05:41 PM
90LSpimpin
16
Jan 20, 2005 06:57 PM
1.8Tities
17
Mar 11, 2003 09:38 PM
