b20b into a 91 teg, i got some questions
Old Jun 13, 2005 | 04:35 PM
tegilator's Avatar
Default b20b into a 91 teg, i got some questions
hey whats up im new at this forum. I am putting a b20b obd2 into my obd0 teg. i want to run it at obd1, but there were no crvs back then, so can i run the motor with a gsr harness and a gsr spoon ecu. will the engine run lean because it is a 2.0. if that won't work i might consider useing the b20 ecu but where would i get a manual ecu from, i heard that they had to be made, like by hondad
And does any one know where i can get a b20b for less than 650 for just the engine.
Old Jun 13, 2005 | 04:49 PM
90b20b4's Avatar
Default Re: b20b into a 91 teg, i got some questions (tegilator)
ok fisrt of all i dont think it would run lean but the simple way of doing this swap is to just keep it obd0 and use the ls injectors distibuter and o2 sensors ihave a 90 teg with a b20 and the how mine is it run perfect but if you realy want to convert it to obd1 i cant really help but i can tell you your looking at an electrical mess good luck man
Old Jun 13, 2005 | 05:03 PM
tegilator's Avatar
k thank yall allot, so i can use the b20b intake manifold or do i just use mine, and the only o2 i use is the one in the header right
Old Jun 14, 2005 | 08:14 PM
tegilator's Avatar
instead of using my ls injectors can i use injectors form an 0bd0 prelude b20, or a prelude b21. because i am planing on alittle nitrous. will my ecu run bigger injectors form the prelude
The Destroyer
Oct 24, 2004 10:45 PM
Jer'rome
Mar 16, 2004 10:08 AM
Charlie Moua
May 20, 2002 12:59 PM
Charlie Moua
10
May 15, 2002 04:59 PM
