96 GSR motor, going in a 92 integra
Old Jun 13, 2005 | 04:17 PM
G2ILS's Avatar
Default 96 GSR motor, going in a 92 integra
So guys I need a lil help on this one. I just got a gsr motor from one of my friend and I wanna install it in my car, so what type of harness do I need or can I use the gsr or my ls. And what axel showld I use? One of my friend toll me to use a B20 axel, I don't even know why he toll me that anyway. And the mounts, what can I do about that, (do they make a kit) or (I have to make my own). Help Pleace!!!
Old Jun 13, 2005 | 04:29 PM
HARI.'s Avatar
Default Re: 96 GSR motor, going in a 92 integra (G2ILS)
all you need to do is convert the motor to obd1. change the distributor, the clips to the injectors and use a obd1 gsr ecu. you will need to use your tranny because the 96 motor comes w/ the hydro tranny. you will also need to use your mounts, unless you are planning to run the hydro tranny, then that's a different story. this is a very easy swap. good luck
Old Jun 13, 2005 | 04:33 PM
vtec65's Avatar
There is a really good write up on G2IC.com that explains that swap. Its under the Teg Tips section. Sounds like a fun project. Good luck
EGandDArida
Aug 28, 2009 06:22 PM
90teg91civic
Nov 6, 2006 05:30 PM
god.loves.ugly
Oct 31, 2005 08:14 PM
Dropped90Integra
Oct 10, 2004 07:18 PM
inochi
Nov 8, 2001 09:05 PM
