lsvtec tming belt?
ok the blocks a b18a1 with a b16a3 oil pump and timing belt along with the a3 b16 head. if i use the b16a3 timing belt and oil pump shouldnt it go on? it wont at all ive switched the ls and b16 water pumps out too and same ****? wtf
^--- those are the same belts and waterpumps. b18c pump = b18c belt : b18a/b pump = b18a/b belt. There is a reason as to why they are different. Go with gsr since you already have the pump. just my .02
GSR/b16/typeR water pumps are the same 22 tooth pulley. Use Gsr/typeR timing belt. LS water pump is a 18teeth pulley so u have to use the LS belt. The 22 tooth waterpump and GSR/Type R belt is the best setup cuz the LS setup will have a little more slack.
Mugencrxsir1
11
Mar 5, 2006 09:09 PM
