urgent !!!!! clutch/gear problem
gear change has been smooth as in silk in all gears since ive had my ek4 over 2 1/2 years.
came to stop few hours ago and couldnt get in any gear. after some fighting managed to get in gear and got home but 80% of time gear change was real tough.
absolutely no warning of any problem whatsoever.
is it likely my clutch has gone ? urgently need car back on road so need to know if i should just order clutch and get car booked in
apart from checkin fluid are there any other simple tests i can do/look at stuff to see what problem is or case of havin garage open box up to find problem ?
im a retard with **** like like this so if it means takin a bolt out somewhere its gonna be garage job
It's most likely the fluid you gotta check. I had that problem times before with my hydro clutch. It was always the fluid. Got some air in the lines or something. Bad cylinders? Had to get a friend to help bleed it and it was fixed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Check your clutch fluid. Your slave could be leaking or a bad clutch master cylinder. Or your clutch just could be completly shot. </TD></TR></TABLE>
JDMgareth
Jan 21, 2008 03:36 PM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
