Lots of parts: Ported Gsr Head, Sleeved Block, Power FC...
Parting out my my car, and selling lots of parts I have laying around.
*SOLD* Bare ported and polished GSR head, ported by Elton at Raceline Development. Never used, new bronze valve guides, and valve stem seals, fresh valve job, and just resurfaced too. Comes with a hondata intake gasket. Selling for $400. *SOLD*
*SOLD* Bare sleeved B18B block. 84mm Darton MID sleeves. <---These are expensive to machine. They cement it in the bottom of the block, as well as cut a lip in the top and the sleeve rests on that too, so the sleeve can't drop. Also comes with a Toda oil pump gear in the oil pump. The gear by itself retails for around $300. Never used, just machined. Selling the block with the gear for $1100. *SOLD*
*SOLD* Arias Forged Pistons 9.5:1 compression ratio. 84mm. Was going to use this for a turbo block but now for sale. Retails for more then $500. These are brand new never used. Selling for $400. *SOLD*
Arp Head Studs. For GSR motor. Brand new in the box. Selling for $100
*SOLD* ApexI Power FC with the Power Commander. Fully reprogrammable computer. You can use this for all motor applications, or turbo applications. For b-series. The plugs are OBD 2a. Retails for $1350. For sale for $1000. *SOLD*
*SOLD* OBD 1 to OBD 2a jumper harness. This is can be used to run the Power FC in an OBD 1 car, or run a newer computer like a type r computer in an OBD 1 car. For sale for $50. *SOLD*
*SOLD* Chipped p28. Jun program. Don't remember what vtec x-over is, but rev limit was 9700 rpm. Selling for $125. *SOLD*
*SOLD* Jun cam gears. These gears are made of steel, instead of aluminum, so they are stronger. Retails for around $300. Selling for $200. *SOLD*
Used Gsr cams. Selling for $100.
Used B16 cams. Selling for $100.
JDM interior for an EG. Comes with rear seats, rear panels, and cargo box. Also comes with the front door panels in the same material, with the power window regulators, but no switches for the power windows. You will have to find some from a coupe. Only thing missing is the front seats. This is the black and red cloth interior, not that crappy purple interior. It also has the slots and grill for the Gathers speakers. It comes with three of the four speakers in the back. The fourth one was busted to pieces when I got it. Selling for $900
Modified by Vanilla4215 at 12:41 PM 7/6/2005
Modified by Vanilla4215 at 12:17 PM 7/12/2005
im interested in the cyl head
what exactly was done to it
was it milled at all?
how bare is it
does it have the cam caps
or any valvetrain parts
lma's rockers etc
where are you located?
how bare is it
lma's rockers etc
The head is ported and polished all the way through on the intake and exhaust sides. The head isn't milled, just resurfaced. The valve job is just a standard one. It comes with the rocker arms, and cam caps, but no valvetrain. Bronze valve guides, and valve stem seals. I'm located in San Gabriel, CA.
typet
Mar 17, 2017 04:03 PM
Running925
Sep 22, 2008 07:43 AM
