aem itr intake in ef
Old Jun 13, 2005 | 09:50 AM
slow91crx's Avatar
Default aem itr intake in ef
i got an aem integra type r cold air intake for my b16 in my crx. it didn't fit. the bends in the second tube are allo wrong. so im curious if i were to cut the tube and add another piece of 3' pipe with a bend in it to make it a functional cold air would it still have a functional gain in horsepower compared to just using the first part of the aem pipe as a short ram. thanks for any advice.
Old Jun 14, 2005 | 02:35 PM
N_A_is_best's Avatar
Default Re: aem itr intake in ef (slow91crx)
this intake fit into my 88 si with a b16
Old Jun 17, 2005 | 04:53 AM
slow91crx's Avatar
Default Re: aem itr intake in ef (N_A_is_best)
did you run the pipe through the hole in the corner of the engine bay where the stock intake box usually mounts?
Old Jun 17, 2005 | 06:31 AM
HONDA_TYPE_R's Avatar
Someone correct me if I am wrong, but don't you need to move the battery to the rear to use an ITR 3" cold air on an EF? I know I could use the 3" ITR cold air on my DA since my battery is in the rear.
Old Jun 17, 2005 | 02:01 PM
slow91crx's Avatar
Default Re: aem itr intake in ef (HONDA_TYPE_R)
my battery is one of those small odyssey ones and it is in a custom mount low down in between the motor and engine compartment on the pass side of the front of the engine bay
Old Jun 18, 2005 | 12:08 PM
yes I did run it in the hole i did have to make the hole like at most 1/2 inch bigger to the engine side to fit properly
Sir_Jon
Oct 6, 2008 01:31 AM
jdm_ef9_b16
22
Mar 14, 2007 07:21 PM
CTR94Joes
Dec 31, 2002 11:51 AM
CTR94Joes
Dec 31, 2002 08:35 AM
mackymcg
Jan 3, 2002 04:22 PM
